Question about Eizo Computers & Internet
I have a new HP Envy Phoenix with 24" EIZO EV2416WFS3-BK EcoView monitor connected via DisplayPort. The monitor is set to 100% brightness, yet few seconds after start it automatically dims and its light remains subdued no matter what I do. I had a very bright monitor before and I am therefore not comfortable with this at all. Is there a way to switch the automatic dimming off? Thank you.
  • Jiri Krejci
    Jiri Krejci Mar 31, 2014
    Apologies, I just found the solution in the manual:
  • Jiri Krejci
    Auto EcoView Menu.
  • Eizo Master
  • 3,320 Answers
Thanks for posting your solution.
Mike
Posted on Apr 02, 2014
Benimur
  • 6966 Answers
SOURCE: dim compaq s510 crt colored monitor
Hi, If you are comfortable working with tools, down to component level and know how to work around EHV areas, then it is possible to increase the brightness of any monitor including the Compaq S510. Make sure that the unit is unplug, Open the back cover and locate the FBT. You have to run/power on/attach a running PC to the unit with the cover off. Extreme care must be exercised. If you are not sure, you're better off asking a qualified service professional to do the adjustment. There two plastic slotted adjustables, focus & screen. Adjusting the screen changes the screen voltage going to the CRT. This will make the display go very dark or overly too bright. Adjust to your preference (not necessarily technically correct) The focus may also be adjusted this way. You have to run the unit with the back cover open for a couple of minutes to stabilize the voltages and the heater/CRT/ Adjust after a couple of minutes if necessary. In other monitors, there is a trimpot (small variable resistor) the adjusts the sub-bright. Further improvement maybe achieved by adding a 100uF/250V capacitor across the supply of the 70+VDC of the 3 gun transistors. If you are sure how to go about this, it is best to consult or seek the services of a qualified TV technician who can either show where and how or do the job himself. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jul 31, 2007
SOURCE: too bright
I just bought an Acer 19 inch this morning and I am assuming you have the same controls on the bottom of monitor. On mine I push the menu button twice....the left arrow once to select the brightness slider.....push the menu button again to turn slider red and active...then use your left or right arrows to adjust brightness...afterwards you use the menu to get you back to the exit button and that's it....I hope Don
Posted on Dec 07, 2007
SOURCE: kogi lcd monitor L5BX
check the amp. settings on the power input.
Posted on Mar 23, 2008
SOURCE: Brightness automatically going low when the brightness is at 100
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Posted on Apr 09, 2009
SOURCE: The contrast of my PC monitor increases automatically to 100%.If
Posted on Nov 10, 2009
Can I hook up a HP L2245wg monitor to a Hp envy laptop
Probably not very easily. The monitor only supports VGA 15-pin and DVI-D video connections. Although you don't specify which ENVY model you have, most only have HDMI and/or DisplayPort outputs. You would need an HDMI-to-DVI-D adapter/converter for the video, and, of course, DVI-D and VGA do not support sound, although it appear the monitor does not internal speakers anyway. You would be better served using a monitor with HDMI input(s) with this device.
Oct 17, 2016 | HP Computers & Internet
How to reset eizo monitor
resetting Eizo monitors - RetouchPRO
www.retouchpro.com > RetouchPRO > Tools > Hardware
Apr 10, 2008 - 6 posts - ‎4 authors
is it possible to rest a CG241W to the default factory settings?..the consultant that is working with us is having trouble getting a decent ...
Eizo
www.eizo.se/default.aspx?page=21
EizoOften there are no faulty sub-pixel on a EIZO LCD monitor, but according to the EIZO... Reset the monitor to the factory default settings by choosing 'Reset* in the ...
Setting Eizo Logo Display On/off; Resuming The Default ...
www.manualslib.com > ... > Monitor > FlexScan S2202W > User manual
The EIZO logo appears on the display when turning on the monitor. This ... default settings, and the other is to reset all the settings to the default settings. ?.
Jan 23, 2016 | Eizo Computers & Internet
Pixelated appearance
Hello Anon, it seems you may be looking at a driver conflict here. Setting up this project is easy; bring in a second monitor and prepare to swap between the two frequently.
1. On the Eizo's menu initiate the self calibration.
2. When the Eizo completes the self calibration and the Pixelation persists, uninstall all the Graphic Card drivers on your computer.
3. Install the manufacturer's specific graphics card drivers from the manufacturers website.
4. If the monitor continues to be pixelated then ensure that your GC is 4k ready. (That it can natively display 2560x1440 @ 16:9 aspect ratio).
I suspect your Graphics Card is not up to par, it likely has full 1080 but not enough to push 4k as your monitor natively runs. Purchase any GC with a 4k ready capacity and you will enjoy the full beauty of your purchase.
Source:
http://www.tomshardware.com/forum/304706-33-completely-uninstall-graphics-drivers-install-ones
http://en.wikipedia.org/wiki/Graphics_display_resolution
http://www.eizo.se/default.aspx?page=11&product=CG277-BK
Mar 06, 2015 | Eizo Nanao Eizo - CG277-BK 27"" Wide...
Shuts down randomly. It shut down twice before any software was installed on it - brand new. Why?
Are you sure that it does not restart after finishing configurations?
All new PC's are restarting a few times during setup.
Jun 29, 2014 | HP ENVY Phoenix 810qe Desktop with 4th...
How to adjust brightness of monitor on on HP Envy TouchSmart 23 All-In-One?
Try using Fn keys to adjust, otherwise check the setting and control panel applications. Could be something wrong with your power plans as well.
May 14, 2014 | HP Envy 23-1070 All-In-One Desktop PC with...
The screen on my Eizo CG241W monitor has begun to display a bright pink background intermittedly. Occasionally the screen displays solid green.
Did you verify that the video cabel is seated properly and no bent pins?
You should also try it with another PC to make sure i is not the PC's video card problem.
Please post back what you find.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 07, 2011 | Eizo CG245W 24 inch LCD Monitor
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
Computers & Internet Logo
57 people viewed this question
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
