Question about Dynex "- 55"" Class - LCD - 1080p - 120Hz - HDTV DX-55L150A11"
Television turns off
Television shuts off and red light goes illuminates on front panel. After unplugging the television from the power source and plugging it back in, it turns on. Sometimes it lasts 5 minutes sometimes it lasts 2 hours then it happens again.
Marcy161
  • 6 Answers
SOURCE: television won't turn on
The light inside the television might be broken that is why it doesn't work.
Posted on Jun 07, 2009
SOURCE: when i turn on the tv i only get a picture on 1/2
There is a high probability this is the tcon board, located at the back of the LCD controller.
I'll need the exact TV model number in order to be able to tell you what exactly the board number is.
It is not guaranteed - it may be the main board or, even worse, the LCD itself; not many people know, but the LCD dispay has quite some electronics literally inside it or glued to it in a totally unserviceable way.
If that electroncis burns out , the whole LCD goes to trash even if it's physically intact.
It's unfortunate, but not uncommon.
Still in your case replacing the tcon board is the first thing I'd try.
Ah, one more thing - sometims the cables that connect the tcon board to the LCD also burn and cause similar troubles. When replacing the tcon board that will become apparent.
Please rate this answer if it helps.
Posted on Nov 10, 2009
budmrtn
  • 11361 Answers
SOURCE: sometimes my tv dynex 32
Look at the power supply first it may be going out; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
You can look here for parts: www.shopjimmy.com
Please post back what you find
Posted on Dec 17, 2009
  • 608 Answers
SOURCE: blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
SOURCE: I just bought 32 inch
This is my second set in as much days from Best buy. Exact same problem.
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv.
Posted on Sep 23, 2011
How do I fix a television that has no audio nor picture when turned on without having to purchase another?
The only thing you can do is look for television repairers in Yellow Pages and take it in for service, or take to the shop where you purchased it.
You can try pressing the button on the Remote for 'Source', just to make sure you aren't on a black screen with no signal input?
Sep 30, 2016 | Insignia Televison & Video
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Take care and good luck
Dec 31, 2010 | Televison & Video
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Red light on front, no audio,video, have unpluged and left unplugged for days , plug it back in and get the same thing
the red light is on because part of the power supply is still alive(usually +5v source), but there could be a problem after the ps that might be causing the tv to go into shut down. that might be why there is nothing happening when power is pressed.
Aug 07, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Dynex "- 55"" Class - LCD - 1080p - 120Hz - HDTV DX-55L150A11" Logo
Top Dynex Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
