Question about Motorola Mobility RAZR V3
How can i fix the flex cable in my phone? it just went blank everything works but i cant see anything
  • dsgb50 Jun 16, 2009
    do you know how much they usualy cost
  • 35 Answers
The only way of fixing a problem such as a damaged flex cable is replacing it, so i suggest you find the nearest cell phone mechanic so they can replace it for you
Posted on Jun 15, 2009
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
My screen went blank what can ido
Hi, my name is jeff and I work for a used cell phone and repair store in Sioux Falls South Dakota called THE CELL PHONE GUY. what the cause probably is, is that you either have a bad connection on a male female part of your flex, or a tear in your flex. if everything else is lighting up except for your screen, thats a sign that your flex might be torn or just dissconected. if you would want it fixed you can always call us at 605 335 0411
Mar 17, 2010 | Motorola Mobility Hint QA30 Cell Phone
My phone is switching on ok and the screen is lighting up but nothing is happening.One minute it was working, the next it went blank. I have been told that it needs a new screen but I dont know why. It...
Hello
I suspect a flex problem
The flex is what connects the screen of the phone to the board of the phone.
what you are experiencing is common with all flip phones and slide phones, the more you flip and slide these type of phones,the flex gets weaker and that may be the cause of the blank screen
What you should do is;
Open your phone,you will see a plasticlike cable connecting your phone screen to the board of your phone(that is the flex)
Remove the flex and fix it back carefully, you should hear a click sound.
Close your phone and switch it on you wont have a blank screen anymore.
if you cant do this yourself,get a person with experience to do it for you
Thank you for visiting fixya
Mar 01, 2010 | Nokia 6270 Cellular Phone
Blank screen when phone flips open
needs a flex cable, about 2 bucks. easy to change
Sep 06, 2009 | Sony Ericsson Z520a Cellular Phone
Screen went blank
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Or it is liquid damage
Mar 12, 2009 | Samsung SPH-m520 Cell Phone
Helio Ocean..blank screen
I managed to fix mine! It takes some doing and is probably not for the faint hearted. You have to disassemble the Ocean from the battery side, removing the qwerty keyboard, to gain access to the slider assembly.
Disassemble the slider (pay attention to the spring!) and clean all contacts and make sure all of the flex cables are seated completely. Mine was working OK the qwerty way, but was blank and/or garbled the long way. Now it works great!
Sep 09, 2008 | Helio Ocean Cellular Phone
My screen on my RAZR oes not work
need new flex cable. not worth the repair - just replace it
Jun 24, 2008 | Motorola Mobility RAZR V3
Motorola RAZR
ya'll sould go to ur near cellphone service to replace the flex cable because is broke
Apr 20, 2008 | Motorola Mobility RAZR V3
Razr v3m
The Flex cable probably went bad on it and yes it can all of a sudden so this.
Mar 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
BLANK
the problem of your phone is the flex cable, just go to your nearest repair phone shop if they have a spare of flex cable for your phone.
peace!
Nov 27, 2007 | LG PM-225 Cellular Phone
Motorola Mobility RAZR V3 Logo
2,257 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
