Question about Philips CDR765 2-Disc CD Recorder
PHILIPS CDR765 2 DISC CD RECORDER
I DONT HAVE PROBLEM ONLY I WANT TO BUY ONE PHILIP 765 CDR RECORDER CREATING MUSIC CD'S
GazllFixIt
  • 103 Answers
SOURCE: won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Posted on Jan 10, 2008
SOURCE: philips cdr 765
I just purchased one from Ebay. It plays fine on both sides. The recorder will recognize CDR's and the display will say recordable media. But, when I attempt to actually record, it won't work. I have another unit exactly like this one and the CD's I have work fine with that unit. I'm guessing this unit's recorder is bad? Any suggestions? Thanks.
Posted on Feb 26, 2008
dunnbiker
  • 8546 Answers
SOURCE: it wont record all my cd tracks, its starts
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
Posted on Nov 20, 2009
SOURCE: Philips 765 CDR - twin deck
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Posted on Dec 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a CDR 765
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Philips-CDR765BK-CD-Players-manual/id/364dj382/t/2/
page 8:
NO-OPC ..............laser power calibration failed. Recording no longer possible
It implies the unit could not satisfactorily adjust to the reflectivity of the medium.
Try another disc or even another brand.
Posted on Feb 27, 2011
Hi, I have a Philips CDR 765 CD Recorder Player. I have been using special disks RAA 80M-51036 80DA and am running out. Where do I get new disks? Peter P. Fuchs
Yours is the only context Google can find for that disk type. What's so special about them?
The recorder will work with any disc on which "the text 'DIGITAL AUDIO' is present!"
Look on eBay. That's where I get mine in bulk. Stick with brand names.
Jul 25, 2011 | Philips CDR765 2-Disc CD Recorder
NECESITO EL PLANO O DIAGRAMA ELECTRONICO DE EL EQUIPO -PHILIPS AUDIO COMPACT DISC RECORDER CDR 765. DESDE YA, LES AGRADEZCO SU ATENCION CARLOS CISNEROS
la solucion a el manual de esta grabadora esta en retrevo.com/manuals.. ellos tienen infinidad de manuales para toda clase de aparatos electronicos incluyendo grabadoras de cdr..espero tengas suerte en encontrar el manual..suerte
Jun 17, 2011 | Philips CDR765 2-Disc CD Recorder
I have a CDR 765 Philips recorder. It doesn't work on recording. The error message is "NO OPC". Thank you
hola
la cdr765 de philips es una grabadora de pc 3610 de philips o hp7200, el opc error es la lente esta mal, compra ina grabadora y cambia los 2 circuitos de la mecanica original de la cdr765 y desmonta la 3640/7200 y ponle los circuitos montas y a disfrutar.
Feb 27, 2011 | Philips CDR765 2-Disc CD Recorder
Can i connect my mixer to the input of the cdr 765 then connect the amp to the outputs. Will this work and record?
If you just treat the CDR as a tape deck, I'm pretty sure your mixer has accomodations for that. Then you won't have to connect the amp to the CDR and anything you want to mix/monitor will be available to the amp.
Jan 11, 2011 | Philips CDR765 2-Disc CD Recorder
Have not been able to find digital cd's. Are cd audios the same for use on philips 870
Philips CDR 870 is designed to RECORD with ONLY Audio or Music CD-R or CD-RW discs !!
The word(s) Audio Or Music MUST be written somewhere on the Cd disc or Cd Covers.
Computer CD-R and CD-RW discs will NOT Record on this recorder !!
My experience of GOOD Audio/Music discs : Philips,Sony,Traxdata,Verbatum
My experience of BAD Audio/Music discs : ALL unbranded discs, Maxell,TDK
Dec 16, 2010 | Philips CDR870 CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Wrond Disc
The disc you need to use to record is "PHILIPS CDR MUSIC". That is what it should day on the top of the disc. On the left side of the disc, it should say "DIGITAL AUDIO RECORDABLE". I spent a lot of money buying the wrong discs before finally finding the correct one. So I know your frustration!
Apr 05, 2008 | Philips CDR600 CD Recorder
Philips CDR765 2-Disc CD Recorder Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
