No sound from 8 keys in mid C range
Loved my PC88 until 1 note became loud. Thinking this was a contact problem, I carefully cleaned them. I reinserted them in the correct order. Now I have 8 dead notes - starting at Middle C# up to G#. I then bought a new contact strip and replaced the middle C octave. Still no change. (Oddly, middle C and the last 3 notes of the octave - A, A#,and B do work) What would cause 8 notes within the octave to suddenly stop working? Would appreciate any help you can give me
  • moonlightmadness
    moonlightmadness Apr 02, 2014
    Let me begin by saying I bought the instrument new, has never been opened or abused, and has sit in my studio ever since. I recently did a hard reset, followed by a diagnostic test that checked out 100%. I replaced the octave with a new pickup strip that did not solve the problem. The only thing I did wrong was to install a few of the original pickups backwards. After the correct installation why did all the other keys (80) come back to life, and not these 8? Could this have an effect on the damaged keys? I have been unable to find a schematic of the key setup to learn how it produces a note. One site mentioned a diode which acts as an off and on switch as I understand it. Could reversing pickup magnets cause a diode to switch polarity?
  • 1138 Answers
SOURCE: Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
Posted on May 23, 2009
petraman7
  • 1175 Answers
SOURCE: My Casio WK-3000 works perfectly
You will have to have someone open up the keyboard and check that the flex-cables from the keys are all connected to the main circuit board
Posted on Aug 17, 2010
  • 5603 Answers
SOURCE: Yamaha PSR 530: D, F#, G
The key contacts which are conductive rubber are dirty.
You need to disassemble to access the silicone rubber domes with the conductive rubber "pills". Carefully clean these pills using a QTip and ONLY 99% isoprophyl alcohol. Also carefully clean the circuit board where these contact.
Posted on Sep 22, 2010
  • 5603 Answers
SOURCE: I have a 6 month old keyboard and have found that
Thisis hard to troubleshoot... The keyboard insynths are usually scanned as a matrix... If a disconnect diode has failed, then wrong notes can be triggered. There is USUALLY rows of the diodes on the circuit board where the keys hit. There are usually TWO contacts per key in order to sense key velocity. The lkey contacts are usually conductive rubber pills pressed against circuit traces under the keys. One sometimes needs to clean these contacts using 99% isoprophyl alcohol and Q tips.
I would do further testing of ALL combinations of notes played together to see if possibly any others show up as that could point to a particular failure.
Posted on Oct 27, 2010
  • 5603 Answers
SOURCE: The "G" note below Middle
The key contact has gotten contaminated. They are a black conductive rubber pill pressed against circuit traces on a board bellow the keys. Remove that key and maybe others to get at the contacts in silicone strips. Clean ONLY with 99% isoprophyl alcohol and Q tips. Clean both the pills (two per note) and the circuit traces they touch. You have to release the spring at the back of each key to remove the key.
Posted on Feb 03, 2011
Testimonial: "thx"
Key B2 playing to loud, not touch responsive
What is your piano brand and type?
Damage to the contact rubber can cause note plays loudly or,
note does not plays at all.
It is caused by:
1. Carbon rubber contacts dirty / dusty (yellow arrow). Clean with a pencil eraser (or cloth). Gently rub it.
2.
Contact rubber is torn (your case). If this happen,it can not be repaired or glue. So, you have to replace one octave.
The yellow arrow indicates the side that is often torn.
Rubber side that is torn, usually not seen, unless we move / pressing gently on top (In the rubber contact position is not installed on the board.)
Examples of this picture was yamaha psr.
Oct 14, 2015 | Music
The third G key on my Yamaha YPT 300 does not cooperate with the touch response feature. Regardless of how hard I press it, it plays the note loudly. All of the other keys are fine.
Below the keyboard, there is a rubber contact (see figure 1).third-g-key-yamaha-ypt-300-not-cooperate-shyexoo0xcste5eq310zs3ot-4-0.jpg Damage to the contact rubber can cause:
- Note plays loudly or
- Note does not plays at all.
It is caused by:
2. Contact shredded rubber. If this happen,it can not be repaired or glue. So, you have to replace one octave as in Figure 1.
Sep 27, 2015 | Yamaha Music
My casio px555r has eight consecutive notes which are twice as loud as all the other keys and not touch sensitive. It is the same for all the sounds. When I turn the sensitivity control to off, the...
Hi, There are two contacts for each key. one makes contact before the other, the time between the two determines the time the key takes to be depressed, hence the touch.
Usually the contacts need cleaning, but in this case as itis 8 notes it may be the common keyboard scanning matrix. The matrix is 8 x ..up to whatever so check the line/column connection, or the associated diode.
Usually this is an easy fix, just time consuming taking the instrument to bits.
Good Luck, Chris the Fader
Jun 03, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
Problem with Yamaha PSR E303 - one note sounds too loud. how can i fix it
I had the same problem, but I had several of them too loud, and it was getting worse. The cheapest, most effective way to fix it is to take a Phillip's screwdriver and take apart the frame, the sides may not screw on but instead may pop out. The keys snap in, so take them out, one octave at a time, starting with the white keys. Keep them in order; don't mix them up. Clean the little rubber contacts underneath them with a Q-tip and some rubbing alcohol. Be VERY careful of any ribbon wires, they are delicate. Do not press the rubbers too hard, clean them gently. When they are cleaned, snap them back in and clean the next octave. Don't just clean the ones that are loud, because the others will be getting loud soon, if one has already started. Good luck! Don't end up with extra screws!
Aug 29, 2013 | HQRP AC Power Adapter compatible with...
Ensoniq kt-88 quirk
those bubble contact strips will have to be completely cleaned, when dirty
the keys will be at max velocity(loud).
May 05, 2012 | Music
My Casio Px 330 keyboard is about 1.5 years old. After the instrument has been played for 20 minutes or so, one note (D above middle C) sounds very loud regardless of how hard it is struck. The problem...
This is a problem with one of the two contacts for that key. The contacts close at different times as the key is depressed and the time it takes between is measured as velocity which is used to control the loudness as in a regular piano. The contacts are conductive rubber pills. After a lot of dis-assembly you can clean them with 99% isoprphyl alcohol and Q Tips. Clean both the pills and the circuit traces on the board they are pressed against. Be very careful of the ribbon cables between the halves of the case.
Jun 02, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
How to change the clutch cable on a 2003 Buell Firebolt.
drain primary fluid,remove clutch inspection cover make sure not to lose spring hex when removing,with small screw driver turn adjuster so the hex nut screws out (left handed threads) remove ball and ramp off cable careful not to drop anything into primary.okay now go up cable to mid-range adjuster and back off (together) then go up to clutch lever and remove there a snap ring that you should replace and be mindful of cable rounting then go back down to primary cover and remove,when putting new one in be sure not to over tighten and don't forget o-ring, after all reinstalled to adjust clutch screw adjuster in to it lightly seats and back off 1/4 to 1/2 turn and adjust mid range until you have a 1/16 to 1/8 freeplay at lever pull and release three times to make sure the ramp and ball have seated good luck
Jan 12, 2010 | 2003 Buell Firebolt XB9R
My subwoofers don't perform consistantly. Sometimes they work flawlessly, other times they make a loud thumping that is not coming from the music (but it does interfere with the music). To be more...
Try turning the gain, or output level down on the amp, if that doesnt solve the problem then check the aux wires and the remote wire for shorts...
Aug 06, 2009 | Car Audio & Video
k24674
jasbo
jasbo
