Question about Dynojet Jet Kit - Suzuki GS650 81-82
No value clearance
There is no valve clearance on 7 of 8 valves
Hey there I need the exhaust and Intake(valve) clearance for a komatsu 300-6 please
note Perform the valve clearance check and adjustment at the engine cold state. 1.Remove all of the ignition coils. 2.Remove the cylinder head cover.
caution Turn the crankshaft always clockwise. 3.Turn the crankshaft clockwise, and align the timing mark on the exhaust camshaft sprocket against the upper face of the cylinder head as shown in Figure. Therefore, No.1 cylinder goes to the compression top dead center. 4.Using a thickness gauge, measure the valve clearance with the arrow shown in Figure. If deviated from the standard value, make note for the valve clearance.
Standard value:
    Intake valve 0.20 ± 0.03 mm (0.008 ± 0.0012 inch)
    Exhaust valve 0.30 ± 0.03 mm (0.012 ± 0.0012 inch)
5.Turn the crankshaft clockwise 360 degrees, and put the timing mark on the exhaust camshaft sprocket in position shown in Figure. Therefore, No. 4 cylinder goes to the compression top dead center. 6.Check the valve clearance with the arrow shown in Figure. In the same procedure as 4.
7.If the valve clearance is deviated from the standard value, remove the camshaft and the valve tappet. For the camshaft removal, refer to Camshaft Removal and Installation . 8.Using a micrometer, measure the thickness of the removed valve tappet. 9.Calculate the thickness of the newly installed valve tappet through the following equation.
A: thickness of newly installed valve tappet
B: thickness of removed valve tappet
C: measured valve clearance
Equation
    Intake valve: A = B + [C - 0.20 mm (0.008 inch)]
    Exhaust valve: A = B + [C - 0.30 mm (0.012 inch)] note The valve tappet ranges 3,000 - 3,690 mm (0.1181 - 0.1453 inch) and has 47 types per 0.015 mm (0.0006 inch). The thickness below a decimal point is stamped on the reverse side of the valve tappet. 10.Install the valve tappet selected through the procedure 9, and put the camshaft in position. For the camshaft installation, refer to Camshaft Removal and Installation .
    11.After installing the timing chain, measure the valve clearance using the procedure 3 to 6. Confirm the clearance is within the standard value.
    caution Completely remove all the old FIPG, which might be remaining among the components. 12.After completely removing the liquid gasket adhering on the timing chain case, cylinder block and cylinder head, degrease them with white gasoline.
    caution The cylinder head cover should be installed within 3 minutes of applying liquid gasket.
13.Apply a 4 mm bead of liquid gasket as illustrated.
Specified sealant:
    THREE BOND 1217G or equivalent
14. Install the cylinder head cover and tighten the tightening bolts using the following procedures.
(1) Temporarily tighten to the following torque in order shown in the illustration.
Tightening torque: 3.0 ± 1.0 N·m (27 ± 8 in-lb)(2) Tighten to the specified torque in order shown in the illustration.
Specified torque: 5.5 ± 0.5 N·m (49 ± 4 in-lb)15.Install the ignition coils.
Jan 23, 2017 | Cars & Trucks
I'm looking for the Toyota corrola 1.6 4AF engine valve clearance
will need a micrometer, valve clearance adjustment tool set for shimmed lifters,small magnetic arm, appropriate shim selecting charts (manufacturer will have this if you can get the nec. measurements).
Measure thickness of shims removed (using micrometer) and use this formula where T=Thickness of old shim; A=Valve clearance measured; N=Thickness of new shim required.
Intake valves: N = T + (A - 0.02 mm (0.008 in.)) Exh. valves: N = T + (A - 0.25 mm (0.010 in.))
Then you need to find shims as close as possible to the calculated values.
Valve clearances (cold) are as follows: Intake0.15 - 0.25 mm (0.006 - 0.010 in.) Exhaust0.20 - 0.30 mm (0.008 - 0.012 in.)
Note, if you are not familiar with precision measuring using a micrometer, this may be better left to a trained tech. These are high revving little power plants and you don't want a problem at 8K rpm.
Jul 14, 2015 | Toyota Cars & Trucks
Need valve specification on 86 chevy nova
from my 1985/1986 official shop manual:
figure 6A1-39 valve stem and guide clearance
max intake clearance 0.08 mm (0.0031 in)
max exhaust clearance 0.10 mm (0.0039 in)
pg 6A1-17 If clearance is greater than the values given in 6A1-39, then replace the valve and guide
pg 6A1-17
standard overall length
intake 106.88 mm (4.2079 in)
exhaust 106/78 mm (4.2039 in)
do not grind more than 0.5 mm (0.020 in)
Mar 11, 2015 | 1986 Chevrolet Nova
What is the valve clearance on a 2007 Holden Rodeo 2.4L Petrol?
They don't have adjustable value they are hydrolic
Sep 18, 2014 | Holden Ute Cars & Trucks
Discover 125 valve clearance
Plz sir tel me how much tapped gauge needs my descover 125cc and com tapped sounds to much plzz sir?
Aug 15, 2012 | 2006 Bajaj Discover DTS-I
What are the valve clearance for BMW 75/6?
valve clearances for a 1976 R75/7 are
Inlet = .004" and Exhaust = .008"
Remember to re-torque the heads prior to adjusting the valves.
Good Luck!
Aug 15, 2010 | 1976 BMW R 75-7
Valve clearances for triumph sprint st
0.10 - 0.15 inlet and 0.15- 0.20 exhaust on compression stroke.
Hope this helps
Apr 23, 2010 | 2001 Triumph Sprint ST
Want to know what the valve clearances are for my 1999 hyndai excel
Adjust the jet valve clearance before the adjustment of the
intake valve clearance.
Jet valve clearance (hot engine)
[Standard value]. . . . . . . . . . . . . . . . . . . 0.25 mm (0.010 in.)
now adjust valve clearance
Valve clearance (hot engine) [Standard value]
Intake . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.15 mm (0.006 in.)
Exhaust. . . . . . . . . . . . . . . . . . . . . . . . . . 0.25 mm (0.010 in.)
Jul 30, 2009 | 1990 Hyundai Excel
Need to know how to adjust valves, or a print-out of adjustment procedure and tools reguired. 1989 toyota gt-s corolla 1600 16 valve 4a-ge cal engine
This engine utilizes shims to set proper clearances, you will need a micrometer, valve clearance adjustment tool set for shimmed lifters,small magnetic arm, appropriate shim selecting charts (manufacturer will have this if you can get the nec. measurements).
Valve clearances (cold) are as follows: Intake 0.15 - 0.25 mm (0.006 - 0.010 in.) Exhaust 0.20 - 0.30 mm (0.008 - 0.012 in.)
Jun 05, 2009 | 1989 Toyota Corolla 2 Door
Dynojet Jet Kit - Suzuki GS650 81-82 Logo
489 people viewed this question
Top Dynojet Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Dynojet Garden Expert? Answer questions, earn points and help others
