Question about Apple iPod Audio Players & Recorders
Ipod wont itunes
Car starts then dies, changed the ignition module it started and ran for a day, now won't start
  • Cindy Sardakowski
    Cindy Sardakowski Mar 31, 2014
    Hi Stephanie, my 98 LeSabre was having a similar issue. The "check engine" light was on for months before we figured it out. It would only run if the car was cold. In other words, if I drove it somewhere & then turned it off, when I went to start it again, it wouldn't start. I found that if I got a jump for the battery, that it would start. But that was not the issue at all. We also tried cleaning the engine sensors instead of replacing them because they were so pricey. Long story short, it was the fuel pump. My brother had to take out the exhaust pipes, then had to lower the gas tank to get to the fuel pump. It was awful. One thing I would recommend, if you end up trying this solution, make sure you change the fuel filter as well because it's so hard to get into there and it only ran about $10 for the filter. The pump was around $70 or $80. Hope this helps.
SOURCE: My Computer and iTunes does not recognize my iPod
my Ipod keeps beeping when plug in computer snd won't do anything else
Posted on May 15, 2008
  • 373 Answers
SOURCE: replaced ignition and steering wheel now car wont start -security light on
Hi......
On your Buick 94.
The problem is the ANTI THEFT SYSTEM..
If you have replaced the ignition switch.
If you are using a NEW KEY, the car won't start.
Because in the OLD KEY, is there a Resistence with a number of ohm's
The computer need the resistence to activate the the signals to operate the vehicle.
OK.. with the New Key and Old Key you can go to any Aloha Smith and they will remove the Chip from the Old Key to the New Key.
And the car must start and running.
But if you are using the Same Key that you have before the repair made.
I recomend to check the 2 Orange wires from the Ignition lock Cylinder to the steering column lower connectors.
Ok I hope this work for your problem.
Any moree info, I will glad to help you.
I'm a Mechanic and have all the repair information for all the cars.
Thank you for use fixya...
Posted on Sep 11, 2008
emissionwiz
  • 75822 Answers
SOURCE: 91 buick regal 3.8 car stalled
I have found the most common part failure issue with the ignition system is the crank sensor, also called by some the TDC sensor.
Posted on Nov 25, 2008
SOURCE: IPOD music list gray in ITUNES
Make sure that MANUALLY MANAGE MUSIC AND VIDEOS is checked.
You'll find it when you click your iPods name.
  • 1596 Answers
SOURCE: 1998 buick lesabre wont start
Do you have a Chip in the Key? if so that Could be the Problem,Ya see the chip is a resistor and if it looses its ELECTRONIC VALUE in its Case Resistance it wont start to test this Turn the Key in the ON posission then do the Screwdriver thing If it Starts Key is Good and Most Likely the Ignition (SWITCH) is Bad <<ELECTRICAL Side NOY LOCKEST SIDE For More Info Recontact Me
rejakwilson@aol.com<<<<<<<<<<<<<<<
Posted on Jan 21, 2009
The engine got wet wont start, why? Where to start looking?
First check the air filter to make sure you didn't suck water into the filter.
Aug 15, 2017 | 1993 Toyota Pickup
Replaced ignition module now it won't run at all
After changing the ignition module, you may have broken the communication between all the components in the anti theft security system. This is common on GM antitheft systems. Check out this link for how it works and solutions to security problems. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 06, 2011 | 1991 Buick Regal
Wont start
try the ignition module in the distributor
Nov 21, 2009 | 1990 Chevrolet K1500
Engine died & wont start no spark ignition coil tested good
try your ignition module in the distributor much more likely. just install rebuilt distributor if that is the problem , if you just replace module the main distributor assem will **** out shortly after.
Make sure you check for broken timing belt also it is one of those two!
May 26, 2009 | 1994 Toyota Camry
90 gmc sierra no start
Try another coil and mount it correctly. Check wires for power.
Apr 15, 2009 | 1990 GMC Sierra
95 tahoe starts fine then dies when warmed up
does gauges go out when that happens because if it does u might want ck your ignition switch electric side of the when it starts getting hot it shuts down kills every thing goodluck let me know what u find hope this helps
Jan 27, 2009 | 1995 Chevrolet Tahoe
23 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
