Question about Sanyo Car Audio & Video
Hi i need code car for seat 7M0 035 152ab
Vwz 7z3x0009368
When i changed the front seats of my 03 car for ones from a 05 my airbag light is flashing code 52,how can i fix this?tried wd40 on connections etc
hi.some veh saves fault memory and it needs to be erased with a diagnostic tool if its a static fault the seats is not compateble or airbag is faulty best to get fault codes read
Jan 17, 2016 | Ford Mondeo Cars & Trucks
How to unlock stereo of 2002 bora with security code
Hi. There. There is a 14 digit number on the side of the radio. vwz?z????? . You can take this to a dealer and they can look up the security number.
Aug 25, 2014 | 2000 Volkswagen Bora
Hi, i need my car stereo code, SEAT AURA SEZ2Z6D2256508, can someone help me, Thanks
contact a SEAT dealer with your vehicle details and they will be able to give you the code if you have the original radio, if not follow this link as has helped before
User login
Jun 03, 2014 | Cars & Trucks
Navigation radio unlock code
Must have a VIN and you will need to pull the radio out for the serial number. It will be a VWZ...... number. You will have to call the dealer with that info to get the 4 digit number. Only a dealer has access to the VW server to get the code.
Dec 12, 2013 | Volkswagen Cars & Trucks
How can I unlock both the CDMA and domestic/international GSM
My Dear Brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 15, 2012 | Cell Phones
Radio Code for Seat Alhambra 2007 RDS needed Please
Changed battery in 2004 Seat Alhambra and now radio is asking for code
Apr 03, 2012 | Car Audio & Video
I need key for unlock "seat aura cd 1000". serial
HI,
PLEASE GO TO THE GIVEN LINK ,HERE YOU CAN GET CODE . THE LINK IS :-
http://www.radio-code.co.uk/grundig-radio-codes.html I HOPE THIS WILL BE HELPFULL TO YOU.
PLEASE DON'T FORGET TO RATES ME.
GOODLUCK.................
Feb 03, 2011 | Car Audio & Video
I have a 1999 cabrio changed the battery now radio is asking for code I do not have the code what is my solution is there a default code i can try
Probably depends on the year/model of the VW. For a 1999 through 2002 Cabrio, you would need to do this: obtain the unlock code that was shipped with the vehicle. If you don't have the unlock code, your local dealership can pull the radio and look up the code with the serial number. Once you have the unlock code, then turn on the radio. You should see SAFE displayed. After about 3 secs, "0001" should appear. Use the station preset buttons 1 through 4. Preset 1 changes the first digit of the code, and preset 2 changes the second digit, etc. Enter all 4 digits of the code. After code is entered, press right side of "Seek" button for about 2 seconds, until an audible signal is heard. If you hose up and get the wrong code...will go back to SAFE displayed. You will get another chance to enter the code. After 2 failed attempts, you have to wait 1 hour again for it to unlock. So carefully enter the correct code the first time.
Volkswagen uses the radio lock feature to prevent unauthorized users of your audio system and will not allow your radio to operate without the proper unlock code.
Volkswagen began using the anti theft feature around 1990 and is still in use in most Volkswagen vehicles today!
Step 1 - Retrieve radio serial#
Your vehicle requires that you remove the radio from the vehicle in order to retrieve your radio's serial number.
Number will start with vwz.Must be a 14 digit number.You must include all numbers and letters included in the radio serial#, including "vwz". Radio serial# Found on chassis of vehicles radio. You must remove the radio from the vehicle in order to retrieve the radio serial number. This number may be stamped in the metal, on side of radio.
Step 2 - Retrieve vehicle V.I.N #Vehicle identification number.Usually found at the bottom of drivers side window.
Step 3 - Purchase code at
http://www.radio-code.com
  • You will receive your radio unlock code, via email.
  • Approximate code retrieval time is 30 minutes to 24 hours.
To do it yourself you will need to have the radio removal keys to unlock the radio compartment .
look at this site and you will have an idea :
http://forums.vwvortex.com/zerothread?id=967146
Jan 07, 2010 | 2001 Volkswagen Cabrio
Cd rom for lg viewrty
Hi Dear,
Click On This Link To Download This:
http://csmg.lgmobile.com:9002/client/app/Verizon/LGMobileUpdate.exe
Or
This Same LG Phone Software Update Yu Can Get From
http://www.lg.com/us/mobile-phones/vwz-phone-software-update.jsp
*Install It, On First Screen Of LGMobile Support Tool There Iz A Button For USB Drivers Click To Install Drivers,
After Drivers Installed, Select Your Phone Model Or Yu Can Insert IMEI Code Or Serial Num [Also Yu Can Get It From Back Side Of Phone Where Yu Insert Battery],
Put Yur IMEI Or Serial, Then Software Will Show Yu Complete Update For PC Suite Applications, Driver And Also Manual Guide For Yur Phone Model,
For To Get IMEI: Dial *#06#
Feb 11, 2009 | LG KU990 Viewty
Air bag code
Hi, ON your 2002 ford taurus, The Flashing code 33 ( B 2292 )
This code refer to : Driver side seat belt pretentioner ( seat belt bucklet) problem.
Check the conecctions under the driver seat.
Repair as need, and recheck if thi code is present.
But if you had an accident on you taurus. You need to replace the Seat belt Pretentioner ( seat belt bucklet)
OK. I hope this information work for you.
Than's.
Jul 11, 2008 | 2002 Ford Taurus
Car Audio & Video Logo
46 people viewed this question
Top Sanyo Car Audio & Video Experts
Colin Stickland
Colin Stickland
xxxxxx xxx
Are you a Sanyo Car Audio and Video Expert? Answer questions, earn points and help others
