Question about Altec Lansing Audio Players & Recorders
Acs 45.1 doesnt power on
When press both buttons do not hapen a power on, i check power supply and it's working, the push button works. i dont know if the PT2256 IC is burn or the 4011. could have some help please.?? Best regards,
  • Altec Lansing Master
  • 3,320 Answers
Take it to a shop.
Posted on Apr 01, 2014
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
I have emachine ET 1641-02w check the power supply and its check out ok but computer wont turn on
I will assume that you have not messed with anything and it just stopped working. So try these steps:
1) Check the power plug, make sure it is plugged into the wall and also into the back of the computer.
2) Check to see that the switch is "On" on the back of the power supply if there is one.
3) Take the case off and look at the power button, try to press it without the case on, perhaps the power button is broken. If that doesnt work try and see if the little wires on the back of the power button are connect and bot pushed off.
4) Check the cables to the power supply, ensure they are connected to the motherboard and not disconnnected.
5) If all of the above do not work, take a power supply from another system and plug it in to *********** board, see if the computer boots normaly then. If that works you can assume the power supply is shot.
Let me know if there is anything else.
-Paul
Jul 12, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
I have a TC24FS2H and it locked, how do I unlock it? Thanks There is a blue screen with a lock in the corner.
Hi, tahnk you for visit fixya. Try this: ( two step)
1.--Unpluged power cord, push pwr button ( hold), connect the plug to AC line and wait for power up, release power button.
2.-- connect power cord, press power button, hold for 15 seconds, release power button.
Let me know if this work ok?. Any questions, I will be here. Thank you
Dec 05, 2009 | Hisense TC24FS2H TV
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
7720 Travelmate turned off and startet again only once
Try without battery.
If it set the problem, let me know
Check power supply if green led lights up
if not try other power supply if yes
Tell me if you ear or see anything on the screen.
Sep 08, 2009 | Acer TravelMate 5520 Notebook
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Same problem, ASPIRE 3680 is dead or something near
laptop mother board is get short its's supply ic is faulty repair this
Jul 21, 2009 | Acer Aspire 3680 Notebook
Turn it on
what red button?
on the Tocco press the right button (end call button) and it should come on.
If that doesnt work try pressing the right button (end call button) once. release it then press and hold it again.
Jan 03, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
111 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
