Question about Panasonic Refrigerators
Panasonic refrigerator repair internal light
How to open the light case?
  • Hanif Jaudin
    Hanif Jaudin Mar 31, 2014
    Panasonic refrigerator Model NR-B362-M
    Thank you for your help.
Micro will not operate fuse was blown so I jumped out fuse and still no power
Your Microvawe is probably shoreted internally. Best case scenario, it has an internal fuse but circuits might have suffered.
If you are not properly a Microwave orven technician and you don't have the proper testers, you should take it to a repair service to get it diagnosed, it it can be repaired for a reasonable cost.
Oct 31, 2015 | Panasonic Microwave Ovens
Panasonic nn-cf760 microwave no power
Someone would have to open and check for voltage--follow the money or the voltage in this case and start by checking cord first and then further in with a volt meter.
If not able to do that have a repair shop look at it.
Dec 22, 2012 | Microwave Ovens
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
Have a Panasonic SA-BT100 which now will not power up, there is no red standby light, have swapped the power lead to check the fuse and still no power - any suggestions ????
These unit have an internal fuse. This will mean removing the power lead, opening the case and replacing the fuse. Probably best to have a professional do it. Sorry, Shouldn't be expensive though.
Apr 04, 2011 | Panasonic Home Theater System System
Hi, I have a whirlpool gold side by side fridge/freezer. I came home the other day and water all over the floor. I opened the freezer and it wasd hot. Opened the fridge, same thing. Light and fan work and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Whirlpool Gold GR2FHMXPQ 21.6 Cu. Ft....
I DID CHIP ICE AWAY CAN IT BE FIXED
If you punctured the evaporator coil, causing a loss of refrigerant, then no practical repair is possible on a compact.
If only part of the cooling coil(evaporator) is frosting over with the remaining part not active, then the system either has a small refrigerant leak or the refrigerant system has developed an internal restriction, and is not a cost effective repair.
Note: If the coil was not punctured and the unit is under 5 years old you should have warranty on it.
*If that is the case, air dry the machine with power disconnected and door left open. Restart, with control set at normal, close door and recheck in 24 hours. If coil is only partially frosted, contact Sears with model number and any paper work you have. They usually keep records on potential in warranty equipment.
Oct 30, 2009 | Kenmore 91365 Compact Refrigerator
The circuit breaker trips when I open the refrigirator even when the ref switch is off
There must be a short in the internal lighting circuit which have one functional component, the switch. It is usually a white push-button inside the refrigerator near the door. The door pushes the switch when it is closed turning the light off. When the door is opened, the button pops back out to turn on the light. In your case, when you open the door you are switching on the light but the circuit breaker trips off. It means the short circuit is in the light wiring and nothing else. Retrace the wiring and you'll surely find it there. Rewire and have a good day.
Sep 24, 2009 | Refrigerators
FREEZER OK / FRIDGE SIDE NO INTERNAL LIGHT & NOISE
your refrig has a bad electronic control heres the part #W10135090 the noise your hearing is an internal relay on the board buzzing trying to turn the lights on. i found the part at sears.com and it was ony about 80 bucks it is a plug and play part so you should be able to replace it yourself. the board is located in the white box next to the compressor in the back of your refrig. thanks peyton
Jan 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Panasonic Refrigerators Experts
Lawrence Oravetz
jhnolson
Are you a Panasonic Refrigerator Expert? Answer questions, earn points and help others
