Question about Magic Chef MCO160UQ Microwave Oven
Power outage does not do anything replaced fuse still nothing mco160UQ
Nothing no lights or anything
  • Dennis Holland
    Dennis Holland Apr 02, 2014
    we had just a blink of a power outage .microwave went off but would not come back on i replaced fuse but still nothing outlet has power every thing else on circuit came on and works.if you blinked you would have missed it .unplugged unit several hours plugged back in nothing no lights no buzz no blink nothing mind you this unit was fresh out of the box 3days ago .
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
Will not power up after power outage
it contains two fuses one of 10 Amps and other for 500mA.
Replace 10Amps fuse with same type and rating.Best thing is to take this fuse and show it to the sale person of electronic shop.
Before you touch any parts of the microwave oven please disconnect the mains power chord and never touch the main power capacitor as this contains very high voltage even after disconnection.
Mar 24, 2014 | Whirlpool Microwave Ovens
MAGIC CHEF MODL MCO160UQ KEEPS BLOWING THE FUSE INSIDE THE MICROWAVE
CHECK THE FUSE CORRECT AMPS OTHER WISE BLOWS THE FUSE AND CHECK ANY SHORT CIRCUIT IS THERE
Jan 08, 2014 | Magic Chef 1.6 Cu Ft Over the Range...
MCO160 microwave and cook vent appliance problem--there was a power surge and now only the light works--is there a reset button?
no reset button. if you are getting lights that means you are getting power and all your fuses are good. you may have a bad control board caused by the surge
May 12, 2011 | Magic Chef MCO160UQ Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the...
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Microwave-doesn't warm anything anymore
Hello rarms1965... chances are that your microwave was the recipeint of a power surge during the power outage you mentioned.. there is no way of knowing what component took the brunt of a surge and it could very well be your magnetron tube, filament transformer of any number of control logic components.. The problem is that anytime you open the case to check things.. unless you know what to look for or even more so.. what NOT to touch ( High Voltage Capacitor comes to mind) you don't know what you are up against. If it isn't a real expesive model ( you didn't provide a brand or model with your inquiry).. then the cost to diagnose & repair could very well exceed teh cost to replace.. Your call.. but whatever you do.. be sure you KNOW what you are doing..
Good Luck my friend..
Sep 24, 2008 | Microwave Ovens
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
Magic Chef MCO160UQ Microwave Oven Logo
46 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
