Question about Miele 24 in. Incognito G843SCVi Built-In Dishwasher
How do i add salt to miele incognito?
What kind of salt do I add to a Miele Incognito
    Problem Solver:
  • 12 Answers
There is a cap inside the dishwasher on the bottom right side, unscrew it and dump a full box of salt in. Clean up any spilled salt and run a rinse and hold cycle to remove any salt residue. Miele recommends using their own salt, available online at www.mieleusa.com or at a local Miele dealer. They don't recommend using water softener salt or table salt. For more help call their tech support at 800.999.1360, they are very helpful.
Posted on Apr 13, 2014
gwshaw71
  • 83 Answers
SOURCE: miele 24" incognito
if it is draining and not drainig all the water out I think you can increase your drain time.Also check to see if drain hose has fallen make sure it is tied to under counter top.
Posted on Nov 22, 2007
  • 122 Answers
SOURCE: salt light is on, no manual. What do I do?
Remove the bottom basket from inside the dishwasher - you will see a twist cap on the bottom of the pan - unscrew and add your salt there - it takes about a box to fill. Reinstall cap, and the salt light will extinguish.
Posted on Jan 05, 2009
  • 122 Answers
SOURCE: Locking clamp for non-return valve
It will have to be ordered from Miele
Posted on Jan 09, 2009
mikadot
  • 2113 Answers
SOURCE: Miele Incognito G843SCVi Plus diswasher will not drain
if the timer is in good condition (no wires burned off)  then it must be the pump itself that need replacing  dishwashers need the drain hose to rise to the counter and then fall again to siphon and make the pump work easier  also it helps keep water in it to stop the plastic parts in it from overheating    if the hose doesn't rise and fall  it may have led to your failure
Posted on Nov 07, 2009
  • 177 Answers
SOURCE: dishwasher does not dry completely--condensation
Makre sure you use rinse aid as this helps evaporate the water at the end of the cycle. make sure the unit is also heating.
Posted on Jan 18, 2010
The red light for salt (PC) is on. What does this mean as we do not have the instruction manual. Thanks
Salt Light is connected to the level of hardness of your local water supply. If your water level is very soft (below 4gr/..) then you dont need salt, but the light will stay on. Otherwise need to add salt and the light should go off (if it is working.)
Apr 16, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
The salt PC light is on....what does it mean
This is just to let you know that the internal water softener needs water-softener salt.
If you do not use the softener (I do not at my house) then the light serves as a convenient on/off light.
Feb 06, 2011 | Miele Incognito G818SCVi Built-in...
Miele incognito won't drain. Intake drain blinking
i also found my miele wouldn't drain after replacing a garbage disposal. it turned out I forgot to knock out the plug on the disposal where the diswasher discharges....Doh !....
Nov 24, 2010 | Miele Incognito G818SCVi Built-in...
Dishwasher does not dry completely--condensation insidethe front door miele incognito
Jan 03, 2010 | Miele Incognito G818SCVi Built-in...
Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Apr 03, 2009 | Miele Incognito G858SCVi Built-in...
Machine off completely
Hopefully a button is jammed in between positions - the lights are just indicating that you need to add salt to the reservoir and that your rinse aid is getting low.
Jan 09, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Missing Panel, Handle & Manual
The Incognito series is made to have a cabinet panel installed on the front - as to blend in with the cabinets - no handle - no panel - cabinet front panel with the cabinet hardware attached
Nov 02, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Miele 24 in. Incognito G843SCVi Built-In Dishwasher Logo
183 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
