Brother 4100e Super G3/33.6kbps
Faxes are coming through and all cables are plugged in properly, but it will not print any documents. It is plugged directly to my Computer. I tried re-starting the computer and fax machine and even switching usb plugs but so far no luck. the cable that goes from fax to computer is a bit loose on the back of the fax, but its been like that for awhile and i dont believe thats the issue. Anything will help, thanks.
DJYar
  • 41 Answers
SOURCE: wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Posted on Aug 23, 2007
  • 106 Answers
SOURCE: Intellifax 4100 won't receive faxes
probably you not properly install a line cord,try to check.check it and this is 100%.if you still have problem try to conect the telephone on telephone line cord aand check the line is ok.
Posted on Feb 07, 2008
Healeyman
  • 1198 Answers
SOURCE: My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Posted on Apr 27, 2009
FixinFax
  • 3085 Answers
SOURCE: Brother IntelliFax 4100e unable to receive fax
It could be some senders are sending over a DIGITAL PHONE LINE. All fax machines are ANALOG.
Posted on Jul 20, 2009
  • 10 Answers
SOURCE: Brother 4100e Fax Machine - not receiving faxes
I have this EXACT problem. I called our phone provider (since it game me a poor line quality error) and they said they're aren't any problems but they'll send a technician out when they can. I'm not going to comment on that because this is effecting our business and she seemed not to care. Big NO-NO in customer service; however... The line picks up and the display reads Receiving - Online. Then I can hear it click which is like it just disconnects. It's like clock work, almost as if there's some sort of timer. I've done the perimeter reset, unplugged the machine, everything (well I feel at least). I almost feel there is a setting on the machine disconnecting it after so much time. Please!!! any help would be tremendously appreciated!!!
Posted on Feb 18, 2010
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
My Intellifax 4100e has 22 faxes in memory. How do I print these ones in memory and then clear the memory?
Hi Veronica, try this: press "menu" then "254" then "fax start". This should print out what is in memory.
Sep 04, 2013 | Brother IntelliFax-4100e Fax
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
My brother intellifax 4100e is not recieving faxes we can send and I called the fax it works and we can copy but cant recieve.
Does the machine actually answer the incoming call? If so does it give an error code? Are you using the genuine brother line lead? Finally make sure the line lead is plugged into the "line" socket and not the "tel" socket.
Aug 15, 2011 | Brother IntelliFax-4100e Fax
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
Can,t print document from computer to a brother 3420c mfc, computer says it is online and ready and the default printer, when i saf print and the prother dialog window comes up i say print and the document...
Hi, Billy.
1. Remove your printer from Printers and Faxes
2. Disconnect the printer cable.
3. Restart your computer
4. Reconnect the printer cable.
5. Your computer should see the printer and install the driver.
Hope this helps.
Sep 26, 2009 | Brother DCP-7030 Digital All-in-One Laser...
Printing all document out the back of machine
There is a lever in the back, lift it will divert the papers to the front again. ( looks like a small door)
Dec 09, 2008 | Brother IntelliFax-4100e Fax
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
62 people viewed this question
k24674
jasbo
jasbo
