Sathyapal@btinternet.comn Sreekala
Btinternet rejected my password to obtain my E mails
If you normally use an email program like Outlook or Mac Mail, try logging in to your webmail. If you can see your webmail OK, then it's likely to be a problem with the way your email program is set up.
http://bt.custhelp.com/app/answers/detail/a_id/49512/c/7339/session/L2F2LzEvdGltZS8xNDc4MjExMzgzL3NpZC96SVllVUwybg%3D%3D
may need to reset password if you can't get into web mail
if you can check the authenication method you selected in the email program
from
http://bt.custhelp.com/app/answers/detail/a_id/9962/c/7339
IMAP incoming server option
Incoming Mail Server: mail.btinternet.com
Port: 993 (this should be automatically populated if you tick the SSL Encryption)
SSL Encryption: Enabled (but not STARTTLS)
Username: your email address including the @btinternet or @btopenworld.com part
Password: your btinternet password
Root folder/path:
POP3 incoming server option
Port: 995 (this should be automatically populated when you tick SSL Encryption)
POP from folder: By default, POP will pull emails from your Inbox
SMTP outgoing server
Outgoing Mail Server: mail.btinternet.com
Port: 465 (this may not be automatically populated on selection of SSL, so you'll need to check this)
Authentication: PLAIN
Nov 03, 2016 | Computers & Internet
I cannot get or send emails. my server is not working
This indicates either an incorrect password or server settings. Make sure your account is setup as follows:
IMAP
Root folder/path:
Folder separator: . (full stop)
Please do NOT enable "secure password authentication" (SPA). It's not needed when you use SSL encryption and won't work.
If your IMAP client supports it, we recommend you also set up the following folders:
Trash
Sent Items
Drafts
POP3
Port: 995 (this should be automatically populated if you tick SSL Encryption)
SMTP
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Feb 22, 2015 | Computers & Internet
Why cant i send emails from pajon1@btinternet.com
To be able to send mails, you have to be logged in to the account. Only then you can send the mail. But when btinternet.com, is a POP3 and STMP server provider, it could be you deleted the settings for the POP server or they are changed one way or another. Please check or fill in both server settings in your browser(s) see if they are correct, or renew them.
Feb 02, 2015 | Computers & Internet
When I try and access my emails on btinternet.com, from iPad I get an error message that the server "mail.btinternet.co" is not responding. I have deleted the Account from the iPad, created it again a
Hi
Being a BTinternet customer myself, I am not surprised that you have a problem IF what you have put here is correct because the server you require is "mail.btinternet.com" NOT "mail.btinternet.co" as you state.
Cheers
Nov 29, 2014 | btinternet.com
Www bt com help
Make sure you enable SSL encryption.
SMTP
Aug 02, 2014 | Amazon Kindle Fire HDX 7
'I can;t receive emails to my btinternet.com account but I can send them ok
This works for outlook 2013 but not sure if its the same for outlook.com....Go into the account settings and click on 'more settings' go to the 'Outgoing Server' tab and make sure 'My outgoing server requires authentication' is ticked. Hope this helps.
Jun 15, 2014 | btinternet.com
2004 nissan sentra rain leak passenger side
Someone in the car watching for leak, someone outside the car with a hose.. Gently apply water to the door area and person inside looks for the leak... Another possibilty. If the water is comning from under the car it can be a rusted place or a body separaion.. harder to find. It can be comning in from around the windheild seal and running down the interior firewall. This is how a shop would find the leak.. but they would charge you for it..
May 16, 2014 | 2004 Nissan Sentra
What causes leaks under dashboard in Trailblazer during rain?
Crawl down there and watch with flashlight while someone sprays area from outside with hose.. when you see where the water is comning in fix it.. this is how a shop would determine where the leak is.. at about $100 an hour.. spray the water gentlly so you can see when it starts comning in. I would suspect windshield seal leak.
May 12, 2014 | 2004 Chevrolet TrailBlazer
I want to check my email at wietskeyoung208@btinternet.com
Point your web browser at http://www.btinternet.com then enter your email address and password.
Jul 31, 2013 | btinternet.com
Sending email
here are the settings for btinternet, if you use "outlook" you must manually configure them!
  • The POP3 server (incoming mail) is mail.btinternet.com
  • The SMTP server (outgoing mail) is also mail.btinternet.com
  • Both need your BT Yahoo! email address and password; you will have to tell your e-mail program that the SMTP server requires authentication.
  • The SMTP server can use either port 25 or port 587.
The most common fault is to provide your ADSL username and password when your BT Yahoo! username and password is what's required.
good luck and regards
Nov 21, 2008 | Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
