Question about Invacare Pronto M51 Power Wheelchair
Invacare M71 surestep disassembly
I don't know how to disassemble the chair. I read the manual, but it makes no sense to me. Help!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Hi there patty ,as a Invacare tech ill try to answer your question, first rotate seat by pulling the lever up on the right side of chair rotate and lift seat up takes 2 people gen. then remove the 4 screws that hold the shroud on that allows you to get at the control box, batterys, and the gearboxes and motors better and motors better
Posted on Apr 19, 2014
4 Suggested Answers
wcdoc1953
  • 278 Answers
SOURCE: i have invacare pronto m51 with surestep the spjis
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Posted on Nov 20, 2010
wcdoc1953
  • 278 Answers
SOURCE: i have oil leaking onto the left side tire of my
Sounds like you have a blown seal on your left gearbox. The only permanent solution is to replace the left brake/motor gearbox assembly. Not exactly a do-it-yourself repair. to verify, you can pull the seat off to inspect with a flashlight or tip the chair up at 45 degrees on the right drive wheel to inspect.
In my experience this is a common problem. It may take some time for enough gearbox grease to ooze out and cause the gearbox to fail. If you run the chair inside the house it will get messy very quickly and the grease stains are difficult to remove. If the chair is upwards of 4 or 5 years consider replacing left and right motor/gearbox assemblies. Hope this helps.
Posted on Dec 17, 2010
  • 19 Answers
SOURCE: I have an invacare Pronto M51 Surestep power chair
If you have had swing away footrests on this chair you can replace them with model PHW93 and must ask to get them in red when you order them from a wheelchair store. If you dont know where a store is that sells Invacare products, call Invacare customer service at 800-333-6900.
Posted on Apr 07, 2011
A Pronto M41 w/ SureStep was given to my Best Friend who has stage 4 cancer throughout her body. It seem to charge fine but a yellow wrench light comes on. Because it was given to her how can I how and...
Since time was important this may be too late.
1. You can download manuals for pretty much anything by asking Google for something like 'Pronto M41 manual'. Manuals help a lot.
2. Googling 'wheechair repair [your town]' will point you to people who can service the chair. You can also contact a local agency for people with disabilities for ideas.
May 07, 2014 | Electric Mobility Invacare Pronto M41...
I have an error code 5 on invacare pronto 51 surestep
This indicates a fault with the left parking brake. Check to see that all the connections are tight by unplugging, and replugging them in, check to see if there is any damage to any of the cables, but first, make sure that the neutral lever on the motor is fully engaged in the drive position...sometimes these get bumped and the controller/computer thinks the chair is out of gear. Move the lever to the full neutral position/out of gear, then reengage it to the drive position.
May 02, 2014 | Invacare Health & Beauty
Invacare pronto m91 wheel chair not getting any power to the switch. Is there a fuse somewhere?
Hello,Download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as A PDF File.It is full of info & you can diagnose your problem to select part required.I hope i have helped,have a nice day,Colin
Apr 02, 2013 | Invacare Pronto M91 with SureStep
I can't remove the seat from an Invacare Pronto M91 VA chair with elevating seat.
single post, lift handle to rotate then pull up very hard!!! four poster lock is between knees release tilt back and remove
Oct 28, 2012 | Health & Beauty
I have an invacare Pronto M51 Surestep power chair from 2008. I need the swing out foot rests in the red color. Can someone help me with this situation and what would they cost-thank you
Mar 08, 2011 | Invacare Pronto M51 Power Wheelchair
My pronto power chair m71 standard the battery is showing low charge within a few hours while being used. It is charged overnight each day. I have to recharge it every 2 to3 hours through the day. Is it...
anne no It means you need new batteries. If Medicare paid for your chair then they will pay for 80% of the repair costs. Contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-80467-2668 and they will send a tech out to check it for you and bill Medicare Hope this helps
Feb 21, 2011 | Invacare Health & Beauty
What to make a 18"
What you need is a new seat sling and back upholstery, the pair of 16" crossbraces plus link bars, and narrow footplates (the standard ones will overlap once you make the chair narrower) or trim them down.
Changing the crossbraces requires disassembly of the chair frames. There are tubes inside that connect the frame sections together, these do not need replacing but is a good time to put a little lithium grease on the tubes to keep the chair folding easily.
Jan 15, 2011 | Invacare Health & Beauty
I have oil leaking onto the left side tire of my pronto m71 sure step invacare chair. why? thanks for your help.
Dec 13, 2010 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
82 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
