Question about Kitchen Ranges
Wolf griddle won't light
Pilot light will not ignite
2 Suggested Answers
  • 193 Answers
SOURCE: Wolf Commercial Gas Range: turning knob on and off very difficult
easy pull the tap apart and clean it with metho and repack it with gas tap grease and take note how you pull it apart also watch out for the spring in side it
Posted on Apr 26, 2010
Need an owner manual for Wolf 6 burner Model CH-4-29-FT11
Try Googling (wolf)(CH-4-29-FT11)(manual) without parens.
Jun 11, 2017 | Kitchen Ranges
Miraclean pilot lighting
I'm not familiar with your particular appliance but all gas fired appliances have a thermocouple and igniter.
the thermocouple is designed to allow/prevent the gas valve from opening.
They commonly go bad on stoves and hot water heaters.
should you wish to attempt a repair yourself l
look on the Internet for a picture of the thermocouple for your unit , turn the gas valve off, then attempt to clean the thermocouple first with some medium grit sandpaper. Just some gentle rubbing a few times can take carbon buildup off.
Then try the start proceedure again. If the pilot light or burners do not light the the thermocouple is the least expensive component I can think of to repla e. usually less than $20 and very intuitive to do.
if that does not work depending on your ability you may either need to replace the igniter or gas valve. Or. Call a pro.
Be safe and keep the gas valve on the unit off until you are ready to restart each time
Hope this helps
May 18, 2014 | Keating Miraclean Griddle, Drop-In, Gas,...
How do you light the pilot for the flat top section of our Imperial 6 top stove?
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
THE OVEN BURNER WILL NOT LIGHT. THE IGNITION SYS IS WORKING. I CAN HEAR AND SEE A SPARK, BUT THE PILOT WILL NOT LIGHT.
If you can hear and see the spark lighting that acually means there is no gas entering. please check that you have have the pilot knob in possition and and and the pilot pibe and orifice is not blocked with dirt.
Jul 29, 2010 | Wolf Range F0027WS36 Gas Oven
Apr 25, 2010 | Wolf Manufacturing Gas Kitchen Range
Oven gas turns off
If your Wolf has pilot light, most cases dirty pilot light (flame looks yellow, normal flame looks blue), you have to disassemble the pilot light to clean it, thermocouple connection is loose, bad thermocouple or bad oven safety valve. you can try change the thermocouple first, if it did not solve the problem, then it will be bad oven safety valve. You can buy thermocouple thru Hardware store. Have fun.
Dec 17, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
My wolf rage doesn't light anymore by turning a nob
some models have one gas pilot for 2 burner front and rear and there is a small pipe that goes front the burner to to the pilot, the burner has small holes facing the pipe the goes to the pilot that's where you take a paper clip or a safety pin and clear or clean the holes, the same thing on the electronic ignition, but some electronic ignition they have a spark right nest to the burner and by looking at the other burner that are working you can see where it's sparking, and clean in between the burner and the spark.
Dec 12, 2008 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Older 6 burner wolf commercial range ignition problem.
If it were the gas regulator, existing flames would go down as more burners are turned on.
There are set screws on the pilot fittings that come out of the manifold, you could try turning those Counter-clockwise to turn the pilots up. (Don't loosen them all the way, they will fall out!) If that doesn't work chances are the pilot stems will have to be replaced to get a higher pilot flame.
Mar 07, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
