Question about Medion MD-1704 PC Desktop
Front bezel need to know the location of 2 springs from sliding door front bezel for on off switch
  • 102 Answers
In a lot of pc,s the front comes off if not open the case and you will be able to see it from there or you should do
Posted on Apr 20, 2014
Front bezel exploded view medion md 1777
Hi Robert, please don't multipost. Someone will answer your question when they have the information.
Mar 31, 2014 | Medion MD-1704 PC Desktop
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
Need to remove and repair headlight motor on a 1988 corvette
REMOVAL & INSTALLATION 1984–88 Vehicles
  1. Open the hood, then turn the headlights on.
  2. Detach the headlight motor wire on the outer side of the headlight.
  3. Turn the headlights off (the disconnected light should stay open).
  4. Unfasten the 4 screws at the bezel. There are 2 at the front and 2 at the sides. Fig. 1: With the hood in the raised position, unfasten the Torx® screws from the outer side of the headlight bezel/trim piece 91036p23.jpg
    Fig. 2: You must then remove the screws from the inner side of the bezel/trim piece 91036p24.jpg
  5. Remove the bezel. Fig. 3: Remove the first of the top bezel/retaining ring screws . . . 91036p25.jpg
    Fig. 4: . . . then remove the remaining Torx® screw 91036p26.jpg
    Fig. 5: Lift the bezel/trim piece away from the headlight assembly 91036p27.jpg
  6. Remove the retaining spring by carefully using a hooked end tool, such as a cotter pin removal tool to move it to the side.
  7. Remove the headlight from the aiming pins by rotating the headlight toward the center of the car.
  8. Unfasten the 4 retaining ring screws, then remove the ring. Fig. 6: With the hood closed, you can see the 4 headlight retaining ring screws (1) and 2 aiming screws (2) 91036p28.jpg
    Fig. 7: Remove ONLY the 4 retaining ring screws, do NOT touch the aiming screws 91036p29.jpg
  9. Remove the headlight pump from the mounting bracket, unplugging the socket as you pull it away. Fig. 8: Remove the headlight away from the mounting bracket, unplugging the socket as you pull it away 91036p30.jpg
    To install:
  10. Install the headlight bulb, making sure it is plugged in properly.
  11. Position the retaining ring and secure with the 4 screws.
  12. Position the headlight into the aiming pins. Move the retaining spring back into place.
  13. Install the bezel and secure with the retainers.
  14. Turn the headlights on, then connect the headlight motor wire.
  15. Turn the headlights off. Both should lower.
  16. Close the hood. Check the aim of the headlights, and adjust if necessary.
1989–96 Vehicles
  1. Open the hood.
  2. Open the headlight door halfway. This can be done either by turning the headlight switch on, then back to the parking lamp on position, or by the manual headlamp control knob (which is located on the inboard side of the headlight door). NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
  3. Remove the screws from the front of the headlight bezel. NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
  4. Remove the Phillips head screws from each side of the headlight bezel.
  5. Remove the bezel by pulling it straight out from the engine side of the hood. Fig. 9: View of the headlight bezel mounting 91036g28.gif
  6. Unfasten the screws from the headlight retaining ring.
  7. Remove the headlamp from the assembly, unplugging the electrical connector as you are pulling it away. Fig. 10: Exploded view of the headlight assembly 91036g29.gif
    Fig. 11: Location of the headlight mounting and aiming screws 91036g30.gif
    To install:
  8. Attach the headlight electrical connector.
  9. Position the retaining ring and install the screws securing the ring to the headlight.
  10. Position the bezel in place on the headlight assembly.
  11. Install the screws on each side of the bezel and tighten to 51 inch lbs. (5.8 Nm).
  12. Install the screws on the front of the bezel and tighten to 17 inch lbs. (1.9 Nm).
  13. Cycle the headlamps, then close the hood. Check the headlight aim, and adjust if necessary.
Jul 07, 2010 | 1988 Chevrolet Corvette
Cant remove door pannel on driver side 04 gmc seirra
1. Remove the door handle bezel.
2. Insert a flat-bladed tool between the door handle bezel and the trim panel in order to release the handle bezel tab retainers.
3. Remove the door trim panel upper extension.
4. Release the upper extension by pulling outward on the front edge in order to release the upper retainer clips.
5. Remove the upper extension from the trim panel by lifting up and out.
6. Using a suitable flat bladed tool, gently pry the manual lock lever from the door trim panel. Remove the trim panel screw.
*Remove the screw (2) from within the opening where the manual door lock lever resides.
*Remove the screw (3) from the opening in front of the armrest.
*Remove the screw located beneath the map pocket, if equipped.
7. Carefully slide the trim panel up in order to release the retainers from the door. Disconnect the electrical connectors.
Note: the top part of the door panel is not separate from the bottom. The "upper extension" is just the small triangle piece directly behind the mirror on the interior.
Simplified instructions
Remove the bezel around the door handle.
Pry out the manual lock.
Remove the 3 or 4 screws depending on options
Slide the door panel up off of the engagement tabs.
Good luck and thank you for using Fixya.
Mar 16, 2010 | 2004 GMC Sierra 2500
We accidently had the door shut on my friends 95 fork truck, and the keys were still in ignition. We had to break the ventglass window, how do we replace that? window
1st. Remove door trim panel by removing the screw retaining the armrest section of the trim panel to the door inner panel and remove armrest.
2nd. Remove the screw retaining inside door handle and remove the handle.
3rd. On vehicles with manual operated window cranks remove the screws retaining the crank, then remove the crank and washer.
4.th On vehicles with power windows, remove the power window switch panel by inserting a thin blade screwdriver between the bezel abd the trim panel, at either side of the bezel. Then carefully pry the bezel from the trim panel and the housing assembly will snap out. Remove the retaining screws from the bottom side of the connector and remove the switch assembly from the connector.
5th Remove door lock control knob on models rquiped with.
6th On models with power door locks, remove the switch housing assembly from the panel by inserting thin blade screwdriver into the spring tab slot located at the top and bottom of the switch housing. Apply pressure and the assembly will pop out. Disconnect the housing from the wirring assembly connector by separating the lock fingers.
7th. If equipped with power outside rear view mirror, remove the switch housing bezel by removing the two retaining bezel nuts and the bezel.
8th. Remove the screw retaining division bar to inner door panel.
9th.Remove the screws retaining vent window assembly to the leading edge of the door.
10th. Lower the door glass to the bottom of its travel.
11th. Pull the glass run out of the upper run retainer next to the vent window division bar. Pull the glass run out just far enough to allow the vent window assembly to be removed.
12th Tilt the vent window and the division bar assembly toward rear of the door. Carefully guide the assembly up and out of the door.
13th. Remove the two upper pivot-to-vent frame screws.
14th. Remove the retaining nut and tension spring from the vent vindow lower oivot.
15. Separate the vent glass retainer and the pivot stops from the vent frame and weatherstripping assembly.
16th. Installation is reverse of the removal procedure. The pivot tension spring should be adjusted so the vent will remain open at higway speeds. Be sure the front door window spacer is in place when installing the vent window and division bar assembly.
I know it is hard to picture it but this is best I can explain with out picture.
Feb 23, 2010 | 1995 Ford F150 Styleside Regular Cab
My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Feb 09, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Would like to locate manual describing procedure for pulling headlamp switch from Ford 2000 450.
Hi....there are spring clips that hold the dash bezel to dash. Carefully pop the bezel out (a small flat tip screwdriver would work well) and there should be 2 screws (or spring clips) that secure the switch to the bezel. Remove those, then the switch and reverse procedure for installation.
Chris
Aug 01, 2008 | Ford F-450 Cars & Trucks
Medion MD-1704 PC Desktop Logo
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
