Question about Video Game Consoles & Games
Where can ground wire on entertainment center
Dont know where to put ground wire
    Master:
  • 508 Answers
Middle whole a electrical socket or power strip is ground.
Posted on Apr 01, 2014
Should I put a mirror behind my entertainment center?
I don't recommend putting a mirror behind your entertainmentcenter for two main reasons. The firstis that when you are watching tv, you don't want to be distracted by the mirrorbehind it. The other reason is that itis difficult to clean behind your television/dvd player/game consoles, so youdon't want a mirror back there displaying all of the dust behind there.
May 29, 2012 | Furniture
1999 honda civic cigarette lighter diagram
The power wire plugs into the center terminal.
Feb 07, 2012 | 1999 Honda Civic
Car lighterr
ONE IS 12 VOLTS, ONE IS GROUND, THE GROUND WIRE IS BLACK, IT GOES TO THE BARREL PORTION OF THE LIGHTER, THE 12 VOLT WIRE GOES ON THE CENTER CONTACT INSIDE THE BOTTOM OF THE LIGHTER.
Jan 24, 2012 | 1993 Ford Tempo
Dryer has 3 prongs wall has 4. new cord has 4 color coded connections. old one does not. how do I know where to put the 4 switches
3 wires -- Outside two wires (Line 1 and Line 2) Center (Nutral).
4 wires-- Green (ground) Red (Line 1) White (Nutral) Black (Line 2).
You have a terminal block on the back of the dryer that has only space for three wires. The Red and Black go on the out side two posts or screws (does not matter which is on the right or left). The White wire goes in the center. The forth and final wire is the Green which should go under a ground screw located near the terminal block. This screw is usually indicated by the ground symbol which is three horizontal lines that decrease in size as the go down. If there is a copper "bridge" from the center of the terminal block to the ground screw remove and discard.
Cheers.
May 17, 2011 | Frigidaire GLER331A Electric Dryer
Cigarette lighter in center console doesn't work and I can figure out why. Checked all the fuses. Any ideas? Thanks!
pull out socket and check for power and ground wire that goes to center should be the power wire and wire that goes to out side should be ground
if u have power and ground then replace socket
if u dont have power check fuses again look for broken wire
if u dont have ground look for bad wire
Jan 30, 2011 | 2004 Infiniti QX4
I am in the process of trying to hook up a 3 prong electrical cord to a 4 prong but dont know which colored cords go where? any advice?
Get an qualified person to do it. If you do not have any idea how to do it, you are better off having someone else do it. If you have a 3 prong receptacle, you need a 3 prong pigtail. And if you have a 4 prong receptacle, the dryer needs a 4 prong pigtail. The green is ground, white is neutral, red and black are both hot (L1 and L2). If you put a 4 prong pigtail on, remove the ground strap between the center post and the case. The green ground goes on the case, white neutral in the center, black or red to the left, what's left on the right. You can interchange the red and black but NOT the white or green. If you use a 3 prong pigtail, the center is the neutral (same as white on the 4 prong) and you will need the ground strap between the neutral (center) and the case. The wires do NOT cross over on a 3 prong pigtail.
Dec 31, 2009 | Maytag Dryers
Ground rod placement
If this is a Sub pannel that is fed from a main pannel then you don't need a ground rod for it, but you do need to run a ground wire in the cable that feeds it. So if it is fed by a 220 volt breaker in the main pannel it needs both hot wires, a neutral, and a ground wire in the cable.
Also when you get to the pannel do not attach the ground bonding jumper to the neutral bus in the sub pannel. each of the 4 wires will be seperated at the sub pannel.
Presto.
Aug 24, 2009 | Electrical Supplies
How do i hook up my parking brake
in the directions it should either tell you to attach a wire from the radio to the ebrake so you can get video. i dont like that idea . first try and ground and ground the wire to the back of the unit. some manufactures incorparate a sequense ex- pull e brake three times then the video will work . what i have done with these is put a small button in the center console or somewhere out of the way . if you want to hook it up the way they want it i need to know what kind of car you have ...
Jun 19, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
I have a broken rca lead and dont want to pull the whole lead out of my car to fix it, i am putting some new ends on it but dont know how to tell which colours are earth
Depends which kind of RCA's you have.....Most likly you have sheilded where there is a center wire and then strands of wire wrapped around the outside of the insulation of the inner wire. That outer wire is the "Ground" the inner wire would be you right and left signals. Good luck.
-Andrew Hawkins
Apr 17, 2008 | Car Audio & Video
Video Game Consoles & Games Logo
14 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
