Question about APC Back-UPS XS900 (BX900) UPS System
Apc xs900 will work off batteries not off ac
Unit has new batteries and new fan. When NOT plugged in to AC unit will come on and work as expected.( Delivering power to output ). Plug in AC cord, unit beeps and both online and on battery lights come on and blink. No power is being output. Also hear clicking sound that happens when both lights blink. Unplug AC cord, turn unit off then back on batteries will produce power to outlets. So then the unit works when not plugged into AC but works off batteries when unplugged.
  • APC Master
  • 3,320 Answers
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Posted on Apr 01, 2014
  • Brown County
    Brown County Apr 02, 2014
    I will download software and try it but I am with you, I think AVR circuitry is bad. Wish I had figured it out before buying new batteries and fan.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Check UPS relays one of the relay might be welded thats the reason why once you plug in on the Mains your UPS start blinking and shutdown the load. Hope this helps
Posted on Jul 09, 2014
2 Suggested Answers
epettingill
  • 175 Answers
SOURCE: APC Back-UPS XS900 shut down
Replace the batteries. Your UPS needs a little battery power to start back up. once the batteries are replaced all should be well
Posted on Aug 29, 2011
I was told the Fan in the unit is no longer working ?can This be replaced with a new one ?the technician advise that it is cheaper to purchase a new one What are my options?
Yeah, its better to buy a new UPS. But hey, if you have the time to search for it go for it. If you call the MFR and just ask for parts dept, then tell them the part no on the fan and order it from them. Hope this helps
Aug 29, 2012 | APC Back-UPS XS900 (BX900) UPS System
My BE500U backup UPS ES is emitting a continuous alarm. Is this a dead/dying battery issue or something else?
I found cooling fan was seized, causing overlheat, and loud whistle. WD 40 eased up the bearings, but I expect I will eventually have to change the fan. Mine is an APC XS900.
Mar 16, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Hello, I have a APC Backup UPS 800 (5 year old) started beeping. Assumed it was a battery problem and ordered a new APC RBC32 battery. When the battery arrived, installed it to the unit only to see...
Because of the electrical burning it is likely that the battery was not the cause of the issue in the first place, it is also likely that the unit will not be able to be repaired by you personally. Often these batteries have very long warranties and coverage, so see if APC will take the unit back along with the battery, if the battery was used in a faulty machine it may have been damaged so i would return that too to make sure that the problem doesn't come back in the future.
Mar 14, 2011 | APC Back-UPS XS900 (BX900) UPS System
I have an APC XS 900 for about 1 1/2 now. I started getting a continuous beep with the overload light turning on. I could not get it to stop, even when the computer was disconnected. After reading the...
You need to reset the unit to recognize the new battery, I had same problem with one apc smart ups on the bench the other day.
On ours we had to turn off the unit unplug the battery wait 5mins
press the on key and hold for 20secs
reconnect battery
plug in to mains
and start as normal. We did this but still had very low battery time and the flashing lights, so we disconnected the comms interface, that sovled the problem.
It may work for your unit, suggest you check the manual before you try if you are unsure
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | APC Back-UPS XS900 (BX900) UPS System
APC UPS XS900 is claiming the battery unit is disconnected
HEY !! it's under warranty. I had one of these freak out on me in much the same way once in a while. I did the online help on APC's website. STAND YOUR GROUND if you don't get the answer you want. I held strong even after the "tech" said repeatedly that it was a building wiring fault, which it's not, and harassed him into exchanging it for a new one. Good luck
Nov 01, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Overload LED lit, constant warning tone, no load on unit. Is there an internal component available to repair this unit?
I have seen this caused by a defective battery. Disconnect the battery and reconnect to AC and see if the overload symptom disappears.
Lou
Sep 11, 2009 | APC Back-UPS XS900 (BX900) UPS System
SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
Feb 27, 2007 | APC Smart-UPS 3000R3BX (SU3000R3BX135) UPS...
APC Smart-UPS 1000VA is powered on but not working
Try turning the unit off for a little while, unplug it from the source even. afer about 5 minutes plug it back in and try it again. You may have a bad battery, how old is the unit. UPS batteries should be changed out every 3 year's, max every 5 year's if you want good reliability. At 5 years you are taking a chance.
Jan 18, 2007 | APC Smart-UPS 1000VA UPS System
APC Back-UPS XS900 (BX900) UPS System Logo
166 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
