Question about Thermador Kitchen Ranges
On my Pro gas range one of the light will not go off
The blue light next to one of the handles does not go off
Our Thermador Pro-Harmony gas range just started to make clicking noises and it will not stop. Nobody turned the stove on. It started clicking on its own. How do we shut it off?
Usually a clicking sound from a gas range is the gas ignitor/igniter sparking to light one of the gas burners
...Check to make sure all functions are turned off. If all are off
could be a defective switch..check to see if you see a spark at any of the gas burners
Sep 09, 2017 | Thermador Kitchen Ranges
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
Frgidaire Pro series gas range not lighting on one burner
there is probably some residue keeping it from sparking. look at 1 of the other burners and take mental note from where the spark is coming from. then spray just a little oven cleaner on and around the one not working. naturally take the metal grid off first.. let set for about 15 min. then wipe away the residue gently as not to damage the igniter electrode.. also there is a possibility the wire leading to the igniter fell off causing this problem.. do the explained first. good luck...
Nov 15, 2009 | Frigidaire PLGFZ397G Kitchen Range
Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
Gas oven doesn't light ACS3350
While the ignitor is glowing, tap on the valve with the plastic handle of a large screwdriver. If the burner lights the ignitor is weak and needs replaced. If it does not the valve is bad and it is advisable to change the ignitor also although not required.
Eric
Aug 28, 2009 | Amana ACS3350 Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
The oven won't light.
jeff, i read your other ? here and i think you probably have a weak ignitor. does the ignitor glow orange?
if it does, or i should say when it does, just tap lightly on the gas valve and see if that causes the gas to flow into the burner and then light.
you can use the handle of a screwdriver to tap with and it wont need to much force.
if this does work, then just replace the ignitor. when they get weak they will glow, but wont draw enough current thru the gas valve to allow it to open. your valve does get voltage but it opens when enough current draw opens the bi-metal portion of the valve to allow gas to flow.
if you have no glow, then its a whole different problem. to be addressed in next comments.
Jan 15, 2009 | Tappan TGF320 Gas Kitchen Range
Range Top Pilot Lights
use a bar-b-que lighter with a loing handle to lite pilot, and yes if the pilot goes out there will be a constant supply of gas going inot home, very minimal amount but as a cumiltve effect not very smart thing.
Oct 23, 2008 | Magic Chef 31000 Gas Kitchen Range
I have a 1948 Magic chef gas oven.Model # 8620. The gas was turned off at my home and the pilot light on the oven went out. The gas is now on and I need to relight the pilot light. I am not sure on the ove...
You did say 1948, as in 60 year old range?
Well, gas ranges did not have fancy safety valves or things like that back then. Most likely when you turn on the gas, a small amount of gas begins escaping at the pilot orifice. Then use a long handled lighter to put a flame there. Pilot should light right away.
Oct 11, 2008 | Magic Chef Kitchen Ranges
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Kitchen Ranges Logo
13 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
