Question about Ovens
Lamona oven light won't switch off
Have used the oven, have switched it off and oven light won't go off?
Start button on Lamona 8301 won't work
The switch could be defective and may have to be replaced.
Oct 07, 2017 | Ovens
Where can i buy a new outer glass for HJA4610 Lamona as mine has exploded?
Have a look at https://www.howdens.com/appliance-collection/ovens/lamona-double-fan-oven/
Oct 07, 2016 | Ovens
I need Instruction Manuel for A Diplomat ADP3120 Softline 600EM Lamona fitted oven
Google it or ask the manufacturer if they have one available
Sep 09, 2016 | Ovens
Lamona 4601 double oven.Stopped heating up so presumed element had packed in?
Try this. ANSWER is not specific to your machine.
You dont need the element to be red hot to know its working,
If its not obviously getting hot after 30 seconds its not working.
I dampen a cloth and wipe the COLD element and then watch the moisture dissapear quickly if the element is working.
First, have you recently done a self-clean cycle?
If so we can suspect that the OVER HEAT cutoff switch was triggered.
BUT before we conclude anything, check the broiler element for operation.
If the broiler also does not work, then its highly likely that the overtemp cutoff relay was triggered. This generally requires a technician. BUT
If you have a schematic, it will show if this switch is a ONE TIME USE SWITCH and needs to be replaced, OR if it is a pushbutton resetable switch. In either case the oven needs to be dismantled somewhat to get at the switch... I would call a technicain.
Aug 20, 2015 | Ovens
I have a Lamona LAM3200 oven, recently the the oven indicator light has been coming on when the oven itself is off? What could be wrong?
sounds like you have a defective oven controller. Be careful, this can be a fire hazard. I suggest you call a appliance repairman.
Dec 30, 2014 | Ovens
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
Hi, I have a Howdens/Lamona HJA3300 electric oven and there is a "booster/turbo" setting to preheat the oven more quickly which you are then meant to switch back to standard before cooking. The problem is...
Turbo often runs all the elements. I reckon that you have a multifunction switch and the other settings (try base heat _ ) still work.
If so >> check fan element
Oct 17, 2013 | Ovens
Ovens Logo
35 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
