Question about Air Tools & Compressors
RS8B1G2 which refrigerant use this compressor
I dont no this old one
Samsung refrigerator not cooling
Sounds more like compressor failing to pump than board fault
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Can i recharge compressor labeled R600a with R134a
If your seriously going to do a conversion I would atleast change the compressor to one that is designed for R-134A. The density in the two refridgerants are different and I just don't see a positive outcome by leaving the old compressor in.
Apr 27, 2012 | Refrigerators
Compressor shuts off when I push the water/ice ddispencer. have to unplug to reset
two things can cause this problem,1water ice despencier is cloged/frozen solid.or 2gas in system is out;you dont say how old the refrigerator is if older than 8/10 years then buy a new one and dont wast money trying to fix.adrian,,,
Nov 11, 2010 | Refrigerators
How do you replace an air compressor in a 99 olds alero
TAKE CAR TO GARAGE OR DEALERSHIP.THEY HAVE TO DISCHARGE AND RECOVER THE REFRIGERANT FROM CAR STORING IT IN STORAGE RECOVER UNIT.AGAINST THE LAW TO LET OUT REFRIGERANT IN THE ATOMOSHERE CAUSING OZONE DAMAGE.WHEN REFRIGERANT IS REMOVED THIS WILL BE THE CHEAPEST WAY.FIRST GO TO AUTO PARTS STORE BUY A PACK OF O - RINGS FOR AIRCONDITIONERS SYSTEM.THEY SHOULD BE GREEN COLOR NOT BLACK ONES.THEY ARE THE UNIVERSAL O -RINGS NOT MADE FOR AIR CONDITION SYSTEM.THE REFRIGERANT WILL DESTROY AND CAUSE LEAKS.WHEN YOU BUY O - RINGS.BUY NEW ACCUMULATOR THE OLD ONE FULL OF MOISTURE.YOU NEED TO REPLACE THE EXPANSION TUBE OR ORIFICE TUBE.IT IS LOCATED AT CONDENSOR LOWER LINE FITTING.BUY 1 BOTTLE OF R- 134 REFRIGERANT OIL. THEN BUY NEW COMPRESSOR.WHEN REMOVING OLD COMPRESSOR POUR THE OIL OUT OF IT.MEASURE HOW MUCH OIL IN COMPRESSOR.OKAY TO REMOVE AC COMPRESSOR FIRST REMOVE DRIVE BELT.THEN SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS ON LEVEL SOLID GROUND REMOVE WHEEL AND SPLASH SHIELD ON PASSENGER SIDE.DISCONNECT THE ELECTRICAL CONNECTOR FROM COMPRESSOR AND REMOVE COMPRESSOR REFRIGERANT LINES.THEN REMOVE COMPRESSOR MOUNTING BOLTS 2 BOLTS AT TOP 1 OR 2 BOLTS ON BOTTOM OF COMPRESSOR.WHEN REMOVING OLD COMPRESSOR.SEE HOW MUCH OIL COMES OUT.SHOULD BE A OUNCE OR TWO.GM COMPRESSOR HOLDS 10 TO 8 OUNCES.BUT WE DONT KNOW HOW MUCH IN SYSTEM.WHEN YOU BUY NEW COMPRESSOR.MEASURE HOW MUCH SHIPPING OIL IT HAS BY POURING IT OUT.TO BE ON SAFE SIDE I WOULD POUR 2 OUNCE REFRIGERANT OIL IN COMPRESSOR. POUR 1 OUNCE OIL IN ACCUMULATOR.REPLACE ALL THE O -RINGS AT THE COMPRESSOR AND ACCUMULATOR AND THE LOWER CONDENSORS LINES WHEN REPLACING THE ORIFICE TUBE.USE NEEDLE NOSE PLIERS TO REMOVE THE ORIFICE TUBE.BESURE TO PLACE THE LONG SCREEN ON THE INSIDE.BESURE TO LUBRICATE ALL O - RINGS WITH REFRIGERANT OIL.WHEN YOU PUT EVERYTHING BACK TOGETHER.DONT OVER TIGHTEN THE REFRIGERANT LINES WHICH WILL CUT THE O - RINGS CAUSE LEAKING. TAKE CAR TO A GARAGE THAT DOES AC WORK.LET THEM PUMP DOWN THE SYSTEM AND LEAK TEST THEN CHARGE AC SYSTEM UP.THIS WILL SAVE YOU MONEY BECAUSE IF YOU BUY A VACUUM PUMP THATS ABOUT $400.00 AND MANIFOLD GAUGE SET A GOOD SET RANGE FROM $100.00 TO $300.00 DOLLARS.SEE YOUR AC COMPRESSOR $270.00 TO OVER $300.00 THAT ADDS UP.HOPE MOST THIS INFORMATION WILL HELP YOU. IF YOU HAVE ANY PROBLEMS THE HAYNES REPAIR MANUAL CAN ALSO HELP YOU IT HAS PHOTOS AND INFORMATION HOW TO REMOVE AC COMPRESSOR.
Jun 18, 2010 | 1999 Oldsmobile Alero
My fridge compartment and freezer compartment is warm. i dont know alot about fridges, so please dont be too technical with me. and its a very old model, 106.769830 E92812566
If both compartments are warm, this means that the compressor is either not running or is running and not circulating the refrigerant. We need to know if the compressor is running. Its the black can looking thing behind the refrigerator at the bottom with copper tubes going to it. If it feels cool to the touch it is not running. If it is warm or hot, it is running and not pumping. If its not running it may be a problem with the thermostat, the defrost timer or the compressor itself. If it is running and hot but the fridge isn't cooling, it may have a leak or a bad compressor or relay.
Feb 20, 2010 | Refrigerators
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
if u can hear the compressor going , then dont worry about fixing it , it would need to be regased , not worth it too old, if u cant hear the compressor going then it wud be a cheap fix wud need a new thermostat or a defrost timer
Jan 31, 2010 | Fisher and Paykel Fisher Paykel 21768 -...
When the compressor (thermostat?) shuts off, it makes a very loud noise. Freezer and refrigerated area are keeping things cold just fine. Refrigerator is 12 years old.
The compressor has 3 or 4 internal motor support springs . Over time , one can rust , due to the contaminates in the refrigerant system . One of them can break free , which will not cause any damage , other than a clunk , when the compressor cuts off . You can still have many years of correct cooling , only the noise will be present .
Nov 19, 2009 | Refrigerators
Compressor will not work on refrigerator freezer works but not fridge
How old is the unit? I would think since it is cooling slight. this might be a thermostat more than the compressor. Dont get me wrong it could be. Is the fridge 12volt dc or 120 ac?
possible connector to the compressor maybe corroded
May 24, 2009 | Refrigerators
I bought a Frigidare refrigerator today. Warranty needed?
its really just up to you. I am a service tech in grants pass oregon and i know compressors dont last anymore. Its because in the last 10 years they have switched from r12 freon to 134a. 134a has higher head pressures which make the compressor go out. If the compressor warranty isnt too much money i would do that warranty. You dont really need the others.
Jan 29, 2009 | Frigidaire Refrigerators
Air Tools & Compressors Logo
81 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
