Question about Sabrent USB-AVCPT Video Capture
Its not loading
The blue light is blinking but not loading
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
There is a blinking blue light under the fan symble that comes on every hour, and wakes my wife up.
when mode you selected will be operational the blue light will blink.every time before the cycle begins the blue light will blink with the slight delay of 10-30 sec.
Sep 12, 2011 | Danby DPAC90061 Portable Air Conditioner
What does the blue blinking light at the very bottom, under the blue power button indicates?
According to the Dell 531 owners manual:
"Drive activity light-
blue light - A blinking blue light indicates the computer is reading data from or writing data to the SATA hard drive, CD, DVD or HDD."
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Safe to ignore. It will blink even when the computer appears to be idle.
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
After installing timer, lights flash on and off.
When lights blink, timer is wired wrong.
Error: The white wire is connected with red-or-blue wire instead of connected to neutral.
Timer has 4 wires: green for ground, black for hot, white for neutral, and red-or-blue wire for Load.
Open following link for wiring instructions and illustration:
http://waterheatertimer.org/Programmable.html#wire
Aug 06, 2011 | Leviton 500W - 6512H-W - Alabaster
My timer has the lights blinking when it turns on
If lights are blinking with Intermatic EJ500 or ST01C, then you have the red and blue wires reversed. The red wire should be capped off. The blue wire goes to Load wire.
Aug 05, 2010 | Intermatic Inc. ST01C Digital In-Wall...
The Blue light does not turn on and my video does not wor. The System has power the Green Light turns on But the Blue light right next to it does not and I get no Video or sound.
the blue light only comes on when you insert a cd into the console and the cd has been loaded.it stays on permanently when the cd has been loaded and blinks when the cd is still loading.for the video make sure your av cable is properly connected and properly working.try testing your cable on another console or using another cable on your console.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
The blue light on the top is not blink
My NOKIA N70 blue light on the top is not blink
Jun 30, 2009 | Nokia N70 Cellular Phone
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Computers & Internet
Sabrent USB-AVCPT Video Capture Logo
Top Sabrent Televison & Video Experts
Lawrence Oravetz
Martin Murray
Are you a Sabrent Televison and Video Expert? Answer questions, earn points and help others
