Question about Craftsman Garden
I need a manual for a craftsman briggs &stratton engine # 536.772321
Need manual
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 31 Answers
You can go to the Sears.com site and see most of what you need to find. Just enter in that engine #. Also go to parts tree.com and see most of their diagrams and print them off to make it easier to work on unit.
Posted on Jun 17, 2014
steve_lima
  • 181 Answers
SOURCE: Briggs & stratton lawnmower engine
on the crank gear there is a circle punched in one of the teeth.then the cam gear has a punch mark between two of the teeth.those two marks must thouch each other.the tooth on the crank will be in between the two cam gear teeth.then the air gap between the flywheel and the magnito is 0.012" .....................hope this helps,let me know
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: Have Craftsman gas weedwacker double line ran out.
take off knob that holds on the spool on bottom of weedwacker, remove spool, there are notches around the outside splines on the bottom of the spool. (the bottom is the end that fits up into the spool housing. there are 2 little holes opposite one another on the spool - one on each section. Cut two lengths of line about 6 feet long. stick line into first hole (near bottom of unit) wrap line around spool. once wrapped line gets short - to the point where you cant wrap it anymore - stick the end into one of the notches - do the same with the other line - insert spool back into housing - make sure spring is attached to the spool and lines come out of the holes in the housing - reinsert knob and tighten - make sure as you are doing this you unseat the ends of the lines off of the notches on the spool and they are out through the housing - tighten knob and you should be good to go
Posted on Sep 07, 2009
  • 114 Answers
SOURCE: Hi Need repair manual for Briggs &Stratton
go to your nearest tool rentall place they might have a book or beable to guide u inn the direction of finding one
Posted on Jan 24, 2010
SOURCE: what brand engine does my craftsman edger/trimmer
It is a Briggs and stratton engine.
Posted on Apr 02, 2011
  • 640 Answers
SOURCE: I have a 190 cc 675 series briggs and stratton
This condition indicates that the float and needle in the carburetor are stuck open. The only solution is to disassemble and clean the carburetor. Make sure that there is no fuel in your oil. If so, change the oil, remove the plug, turn engine several times to put oil back to where it needs to be (fuel acts as a thinner), replace plug and you should be ready to start.
Posted on Aug 08, 2011
Need REPAIR manual Craftsman rototiller model #917.292492
check out what's avaiilable at this web site. ;Note that engine information can be found at the Briggs & Stratton web site
http://www.searspartsdirect.com/model-number/917292492/0247/1508100.html?searchType=modelSearch&q=917.292492&searchTerm=917.292492
Apr 11, 2017 | Craftsman Garden
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
Need to know the torque sequence for my briggs & stratton 6.25hp craftsman push lawnmower engine?
One method that works is to use a star shaped pattern and torque the bolts in 2LB increments. Be careful not to overtorque the bolts.
Jul 15, 2014 | Briggs & Stratton Garden
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
WHAT WEIGHT OF OIL IS NEEDED FOR A YS4500 W/ A 21 HP BRIGGS AND STRATTON MOTOR
I have used 30 WT oil in all my 4 cycle engines. You could google Briggs & stratton to get some info. Sears will sell you an operators manual. Try googling Sears, you might get lucky & get the manual for free..
Louie Almond
Mar 27, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at wadembly@aol.com
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
66 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
