Question about Health & Beauty
Need a manual for Accutek A-PT80 scale
I need a manual for this scale
My Accutek not blowing out the air from the fan what is wrong with my fan
There is an 'enter' side and a 'blower' side to each fan. Is it spinning the proper way?
Jul 02, 2015 | Accutek AOJ-1601 Stand (Pedestal) Fan
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Agent in Malta for accutek fans
www.accutek.com.tw/
Consider asking the company if they have an agent there.
Oct 20, 2014 | Dryers
I have an Accutek fan that is not working. Where can I have it fixed in Cape Town? I would like someone to look at it to see if it can be repaired before I incurr costs?
I also have the same problem with my Accutek fan. I think it is the bearing that is going as it is making a noise .It is like running and then jamming as something is restricting it. I also live in Cape Town and looking for someone to fix it.
Jan 24, 2014 | Accutek Dryers
I have a A0X-1202 Accutek fan, it wouldn't start. It worked fine before but today it just won't start. Can it be fixed? What possibly could be the problem?
1st, remove the poer cord from your fan and determine if you have any breaks in the line by checking the voltage ( 120 volts) coming from the bare wires when it's plugged in. If nothing registers on your volt-multimeter, you can easily repair the cord or just replace it. Check to see if that works, and if not, ask me the next step.
Sep 21, 2012 | Accutek AOJ-1601 Stand (Pedestal) Fan
Lost manual, need instruction on how to reset Taylor 5700 BMI
personalcare.owneriq.net/manuals/mfg/taylor/5571.html
go to that address and you can download the manual.
Feb 03, 2009 | Health & Beauty
Need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
Jan 21, 2009 | Taylor 5599 440 Pound Tempered Glass Body...
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Health & Beauty Logo
46 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
