Trane XR12 Heat doesnt work after 15minutes of operation
When I set my thermostat to heat, the heat turns on and the air temp is hot from the registers but after about 15minutes of operation I notice the air temp from the register starts to cool to room temp more or less. also there is a noise coming from the outdoor unit that sounds like pressure venting. this seems to coincide with the cooling of the air in heat mode
  • Jeff R
    Jeff R Mar 31, 2014
    Someone told me it could be the reversing valve although it sould not stay open that long
  • 1,253 Answers
Sounds to me like the outdoor unit is malfunctioning. Could be a control board going crazy, could be the reversing valve leaking. A trouble call to the local contractor is the best idea, preferably a firm that deals with your brand.
Posted on Apr 01, 2014
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Trane xr12 heat pump switching to aux
Sounds like the compressor is not running. Possibly a bad capacitor. Check system in cooling, see if it cools. If it does cool then you likely have a reversing valve issue. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 30, 2017 | Heating & Cooling
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Jan 02, 2011 | Heating & Cooling
No heat on trane XR12 heat pump
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Dec 25, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
98 dodge stratus no heat and temp. gauge dosen't move
thermostat is stuck open replace it and it should work
Jan 22, 2009 | 1998 Dodge Stratus
Heater does not blow hot air on full heat setting
the problem is caused by the motor that operates the air temp blend door motor in the heating ducts, it blends air between AC and heater core tro give desired outlet temp.
Dec 12, 2008 | 2000 Chevrolet Silverado 1500
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
