Question about HP Pavilion Slimline s3700f PC Desktop
Front female usb ports
Need to replace if possiblee
  • Daniel Wakefield
    Daniel Wakefield Apr 08, 2014
    Hi Johnny carpenter, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Do you have replacement ports? Have you worked inside computers before?
How do I fix a cellphone that won't charge at all when it is plugged in. I've tried turning it off, taking the battery out, and everything.
It could be a problem with the female usb port on your phone. Try shining a light inside where you plug it in and see if there is anything there. Here are a few phones with the female ports where you plug in your charger.
25894004-w32j5maowckw4u0pbavragxd-2-0.png Use something like a toothpick to clean out inside there. If you use something too hard, it can damage the inside of the port.
If there is nothing in there, it could be the cord. Have you tried multiple cords and cubes (wall adapters)? Here is the iPhone version, but really all that changes is the business end of the charging cord, so it still applies.
25894004-w32j5maowckw4u0pbavragxd-2-1.jpg If you have tried multiple combinations of cords and wall adapters, then it might be that the charging port on your phone is broken and needs repairing. A sign of this being the case could be the cable being able to wiggle around too much when plugged into the phone.
If these other solutions do not work, you may need to replace the female micro/mini usb port in your phone, which could be above your skill set and you may need to hire a professional, or someone who knows their way around a soldering iron.
Oct 05, 2015 | ZTE Cell Phones
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
Kind of usb port is female
This is what a Female USB port looks like. The white part may also be black or blue depending on the version.
Mar 08, 2015 | Computers & Internet
My usb in front of the cpu have some problem
Most likely either the USB socket is defective internally, or it has broken off of the circuit board that it is soldered to internally. This usually happens from excessive use. The ports at the rear are plugged in typically once for a long period of time, but front ports get a lot of wear and tear. A repair or replacement is NOT recommended, unless you have experience working with/on electronic circuits.
A quick remedy would be to purchase a USB Extender cable. It has a Type A Male on one end and a Type A Female on the other end. The male would plug into a USB port on the rear of your computer and the female end would be available at the front. If it fails, just change out the extender. Or you could purchase a USB 4-port Expander hub and do the same thing.
Hope this helps.
Apr 30, 2014 | Computers & Internet
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
http://pinouts.ru/Slots/USB_pinout.shtml
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
Wher are the USB ports on Advent DT1308
Advent Advance DT1308 Desktop PC?
http://www.pcpro.co.uk/reviews/desktops/370084/advent-dt1308
Look at the Back of your Advent computer tower.
Look at the lower left.
This rectangular area is the I/O area.
Input/Output area.
This is where Input and Output devices are attached.
Look at the Purple round PS/2 port all the way at the right bottom.
It's where the Keyboard plugs in.
Right above it are four USB ports.
http://en.wikipedia.org/wiki/USB
There are several styles of USB ports. This style is a USB female type A,
http://en.wikipedia.org/wiki/File:USB.svg
(Standard A )
According to the review (Specs tab), there is supposed to be two USB ports in the Front. (Front Panel)
I do not see them.
Could be behind a door that swings open.
Looking at the Side View, with the Side Panel of the computer case removed, the USB cables going to these front ports, are going towards the bottom/front.
Regards,
joecoolvette
Apr 25, 2012 | Computers & Internet
Strange question, but the USB port on my NW-HD5
Hello
Do not feel like it is a stupid or dumb question, because by asking, we all learn.
Here s a picture of how the male and female USB should look like.
This is what the male USB should look like:318bb1f.jpg
This is what the female USB should look like:
The male plugs into the female. Hope this can be of help.
Kind regards
Andrea
Dec 17, 2009 | Sony NW-HD5 MP3 Player
I have my female usb part for my external hard
You can get these parts from any good electrionic parts suplier eg Maplin, Mouser, RS components, etc but need to be competent at soldering.
You could just get another enclosure
Or you could remove the drive and install it inside a pc that has a suitable interface
Plenty of options
Aug 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Question on the back ports on head unit
Hello BCRich356,
The USB input to the KDC-X993 is a cable hardwired into the back of the unit. To extend the length of the cable, you would need an extension with a male connector (like on the thumb drive itself) on one end and a female connector (like the thumb drive plugs into) on the other end.
There is no port on the back, it's hardwired. Just like the AUX cable.
Hope this helps.
May 05, 2009 | Car Audio & Video
HP Pavilion Slimline s3700f  PC Desktop Logo
19 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
