Question about Onkyo TA RW544 Single Dual Cassette Deck
Recording problem onkya model ta2090
RECORD.  Montor input  shows normal reasonable volume and can be
set to any level.  Monitor  TAPE  shows  FULL RED both Channels
only drops down if intput set to almost zero.  Same when auto bias set or normal record mode.
Output very distorted.  If play back tape which has been set with auto bias
test sample tone is just fine.
Have schematic and scope    where do we look first ??
Thank You
Al Collins San Diego Ca
  • 1,512 Answers
Re: recording problem onkya model ta2090
Check electrolytic caps about the dolby chip. have seen caps (maybe 100uf) go dry and produce problems like this
Posted on Dec 09, 2007
0 characters
3 Points
I want to begin converting music from my computer onto cassette tapes using a device i've just bought. Can i use this device to firstly, override tapes? And Secondly does my record button even work?
check the top of the tape cassette if plastic removable tabs missing it will behave like a read only cassette if missing sticky tape can be used to cover the holes to make cassette recordable.
Jul 11, 2015 | Tape Decks
Fisher dual cassette player recorder doors wont open
The eject mechanisms may have simply aged to a point where they no longer work. There could be dried out lubricant or a failed mechanical part.
Mar 23, 2014 | Sony Tape Decks
Reel to reel wont record with microphone
When I put a tape in and press play, the spools will not turn. There is power, but it won't play the tape. It's like the turning spools are stuck .
Feb 28, 2014 | Tape Decks
Need manual
Ron there is no such manual except those that might come with the Equalizer- Actually , the process is very simple. You take the output of the equalizer in hook to tape in. Tale the record out of the tape loop and hook to input of the equalizer. Then the equalizer will work when the tape look (tape monitor) for the receiver is selected- that is why it is called a tape loop as signal goes out and comes back in. If you have Pre outs and Pre in you could use it there too. In the tape loop connection any tape deck is then hooked to the Equalizer tape inputs- some have two.
Dec 31, 2012 | Tape Decks
Ive got the sony set up to a denonm38 it plays but no sound.cds and tuner work through speakers but not tape deck.i havnt played a cassette for quite a while maybe ive overlooked something
Are you sure you have pressed the tape monitor switch or button on the amp or receiver? The Tape Monitor switch is the most common failure in amplifiers and receivers provided the tape deck is hooked into the correct place on the back of the unit. The tape decks outs go to the play in on the amp and the Record outs go to the tape decks inputs.
Nov 04, 2012 | Tape Decks
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
How to hook up to tv
For what purpose? To Record the unidentified TV audio or to Play tapes through the TV's speakers? Any tape deck records FROM a standard Line Level output of another device and plays out TO a standard Line Level input of another device. If your TV has those, go for it.
Looking at manuals may help, too.
Aug 16, 2011 | JVC TD-W254 Single Cassette Deck
I just bought a used PDM510. Most everything seems to be in working order, however, I can't seem to enter record mode or hear audio through line inputs. I'm not sure if the machine is broken or if I'm...
to hear the audio fold back in prerecording mode you will need a tape that still has a security tab in it if not put some tape over the whole or even block the hole up
supply the tape unit with a good signal and then hold down the pause button and press the record and play button at the same time. you will then be able to monitor the sound you are about to record. use headphones as this to stops background noise in your ears and allows you to focus on the sound, "its another world inside your cans" adjust the input level until just peaking into the red. when you are ready to record leave the record button alone and the stop button and the play button just release the pause button and away you go. to stop press stop to stop recording say to cut out an advert or something just press pause.
Apr 08, 2011 | Marantz PMD510 Single Cassette Deck
Tacsam DA 30 has no playback
Chances are that pre-amp IC that controls both channels has failed. Follow the wires from the tape head and trace the signal. Better still start with the output of the deck and trace backwards. If you touch the audio circuit with an insulated screwdriver (don't short anything) it should buzz. when you find something that buzzes on one side (coming out) but doesn't buzz on the otherside (signal going in) then you have found what needs to be replaced.
PS don't touch the power section.
Aug 20, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Teac cassette deck records at very low volume
Tape decks have a record amp, depending on the age of the machine it will probably be an IC. Yours might have failed. See if you can identify it or try and get a C diagram. To locate it follow the leads from the head. If your lucky it might have 'Rec Amp' on the board. Their maybe a preset marked 'rec level' for each channel. The (IC) box with legs - near them will most likely be it. Don't adjust the presets unless somebody has tampered with them before. (they will look to be sitting around the middle if they are OK).
May 30, 2008 | Tape Decks
Tape Decks Logo
203 people viewed this question
Top Onkyo Tape Decks Experts
Gyula Lacz
Bruce Showalter
Are you an Onkyo Tape Deck Expert? Answer questions, earn points and help others
