Question about Uniden Cordless Phone
CID and Phone book do not work
CID, phone book, and answering machine no longer work.
Check power suply to phone does program light up?
Posted on Apr 01, 2014
  • 146 Answers
SOURCE: My new Uniden Phone/Answer machine is loading down my fax line
I have searched the user manual and can find no help on this matter, although there are help numbers listed and I'm sure they can advise, here is the link to the main page and there is a link to a pdf manual download if you don't already have one http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
However, it may be that you could use a T adaptor or socket doubler on the line jack and plug both in. good luck !
Posted on Jan 16, 2008
SOURCE: Phone and answering machine are connected properly
how to restart my phone uniden the model is DXAI5588-2
Posted on Oct 23, 2009
ginko
  • 19396 Answers
SOURCE: We have a 3+1 Uniden
Hi.
Try using the procedure below to reset the phone:
  • Disconnect all power adapter cables from wall sockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handset (or handsets) to cradle. I wrote at plural because the phone system may have more than one cradle/handset.
If that does not work, then the phone is defective.In that case you will need to replace/repair the faulty handset or the whole system.
If there is no communication with base, then either in cradle or handset can be defective. In that case contact Uniden.
See:
Contact - Uniden ' A World Without Wires
customer service phone numbers and support
UNIDEN.COM.AU
First try the reset procedure described above.
Regards.
Ginko
Posted on May 18, 2011
joeguest2
  • 2080 Answers
SOURCE: How do you remove the New CID totals from the Uniden DECT 6.0 phone?
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Since you did not specify exactly which model of Uniden phone you have, hopefully some generic instructions will help you out. Here is a direct link to the ONLINE USER'S MANUAL for a basic Uniden Dect 6.0 Cordless Expandable phone (model D1660):
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660om.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 8 of the manual for detailed instructions on how to access and view the Caller ID list as well as delete entries from that list.
Normally, once you access the Caller ID list, then scroll through it and view all the NEW caller entries, these calls are then automatically transfered to the OLD Calls list. NEW CID entries are just those calls you have received since the last time you manuallly reviewed the Caller ID list.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Nov 20, 2011
SOURCE: Uniden Dect1480 6months old Unable to access the
Unplug the base (the power cord) wait a few seconds and re-plug it in - it should be fine then!!
Posted on Dec 23, 2011
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
How do I identify an incoming phone number?
You need to have Caller ID from your phone Co. 1st. Then when you get a call the number shows up as the phone rings.The handset also has a button called,CID,which you can press and see the last 100 calls you've recieved:)
Sep 27, 2014 | Uniden D1680-3 Cordless Phone - Dect 1 x...
I want to see the phone number of prson that called me and i answer him. KXT7730
Your Panasonic System display phone is capable of showing CID if you have a CID card in your TA/TD/TAW or higher series phone system and have done some programming. The card part number ends in 93 and installs inside the cabinet for the particular system. After the card is installed, programming turns it on to tell the line to wait for the CID string before ringing the phone.
Your phone also has to be ringing or you won't see CID until you answer the call.
Carl
Apr 03, 2011 | Panasonic KX-T7730 Corded Phone
Hi-Our GE spacemaker phone will no longer record messages when someone attempts to leave a message. The phone will just ring and never attempt to record. It was working fine for until recently. We have...
Apparently you have the answering machine turned off.
When speakerphone is OFF (not in TALK mode), press flash/program button and CID VOL(+) / CID VOL(-) arrow keys to move the pointer > to point at ANSWER ON/OFF, press flash/program button to show SET ANSWERER ON OFF.
Use the CID VOL(+) / CID VOL(-) arrow keys to select ON.
If you need one, you can download the manual here.
Feb 09, 2011 | GE Spacemaker 26976 Cordless Phone
I cannot go down my list of who has phoned
Press the 'CID/FLASH' button to review the telephone-numbers of those who have called you.
Then, use 'UP/DOWN' to scroll through the list of callers.
Set the Panasonic to answer after *EIGHT* rings -- after *FOUR* rings, SaskTel's voice-mail will "answer" the call. So, there will not be "fifth" and "sixth" and "seventh" and "eighth" rings, and so your answering-machine will never get a chance to "answer" the call.
Jun 05, 2009 | Panasonic DECT 6.0 Expandable Cordless...
GE CORDLESS PHONE ANSWERING MACHINE
The flashing CL means the clock on the phone has not been set. You can try to set the clock using the Menu option on the handset, but the easier option is to simply call the phone from another number. When this happens, the base of the phone gets a CID time and date stamp from the time calling, and the clock is set. You'll notice that the CL is no longer flashing after the phone has received the call. You don't even have to answer the phone- just let it ring once or twice and you're all aces.
Feb 26, 2008 | Uniden Cordless Phone
No CID
This message is in an area that discusses the 25202RE3. If you really have the 202, this model shouldn't have the CallerID capability. If there was ever a model 25204RE3, that model probably has it.
If you bought it brand new, then you might have the space-age chrome/blue-plasma model (2542YRE3?, where Y is either 3, 4, or 5). If Y is 3 (and the model number system holds), you don't have CID/VM. If Y is 4, you do. If Y is 5, you have a built-in answering machine as well.
Jan 15, 2008 | RCA 25202RE3 Corded Phone
Uniden Cordless Phone Logo
47 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
