Question about HP LaserJet 4730 MFP Printer
Error 30.01.02 before and after change of scannertop
Firste I changede feedroller and sep pad and mylarsheet, but the problem continued so I changed the hole top (ADF) but the problem continues. 30.01.02. Do you have any idears?
    New Friend:
  • 26 Answers
30.1.2= A jam has occurred in the ADF. Recommend action, turn the MFP off and then back on to try to clear the message.
If the message indicates that a jam has occurred, clear the jam, if the message is still there. Check that the cable between the print engine and the scanner is secure..
Turn the MFP off, remove all memory DIMMS or third party DIMM from the MFP (Do not remove the firmware DIMM) remove all EIO device from the MFP. Turn the MFP on
if the erropr no longer exists, reinstall each DIMM and EIO device one at a time, make sure to turn the MFP off and no again as you install each device. replaced a DIMM
or EIO device if it cause the error, if problem persists upgrade the firmware before replaced the DC controller. Replaced the formatter and calibrate the MFP.
take a look here
http://h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-420/34967/1/357783.pdf
Posted on Apr 01, 2014
  • aurelio sorgi
    aurelio sorgi Apr 01, 2014
    look inside for paper jam and check the sensors.
  • aurelio sorgi
    let me know
My lexus is200 has a sqealing nose from front of the car it starts at 40mp and stops at 20mph have changed the discs and pads and caliper is fine
if it is brakes area the new pads will be bedding in to new rotors
if calipers are not new and only inspected needs looking at again seized calipers or sticky guides
lexus engine bay squeals
can be idler pulleys /sep belt /any bearing driven unit off the serp belt
alternator /power steer pump/ air con8dc2c230-44e0-432b-9470-573f8cfe347a.jpg
Oct 14, 2016 | Lexus Cars & Trucks
What tools do i need to change brake pads on 2005 yukon xl
Jack, wheel wrench, socket set, large screw driver, pair of pliers or grips. Lithium grease for the pins. Watch all of these videos. .spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
g-img{display:block}._WCg{display:block;border:0;position:relative} Search Results
    How To Install Replace Front Brake Pads 2000-06 Chevy ...
    9k=? 4:46 https://www.youtube.com/watch?v=nPohZtD8zlA May 27, 2014 - Uploaded by 1A Auto Parts http://www.1aauto.com/brake-pads/i/1abps00080 1A Auto shows you how to ... Front Brake Pads 2000-06 ...
    HOW TO INSTALL REPLACE GMC YUKON DENALI ...
    z? 14:10 https://www.youtube.com/watch?v=um7dt_yvZ1s Sep 20, 2012 - Uploaded by TheRykerDane Video on how to change the brake pads and rotors on a 2004 GMC Yukon Denali. Changing these parts ...
    How to REPLACE INSTALL BRAKES and ROTORS GMC ...
    2q==? 11:32 https://www.youtube.com/watch?v=UWqows3P4DE Feb 11, 2012 - Uploaded by TheRykerDane Video on how to change the brake pads and rotors on a 2004 GMC Yukon. Changing these parts ... Would ...
    GMC Denali Brake Pads Removal and Installation - YouTube
    z? 3:45 https://www.youtube.com/watch?v=uEKs8nphVxU Oct 24, 2012 - Uploaded by AnotherLookFilms Remove and Install rear brake pads on your 2006 GMC Denali XL. ... 9-21-13 2007 GMC Yukon rear brakes ...
    GMC Yukon Denali Front Disc Brake Pad Replacement ...
    2q==? 8:21 https://www.youtube.com/watch?v=w_gn_l5lYkw Jun 20, 2013 - Uploaded by AMS Automotive Watch the proper procedure for replacing front disc brake pads. Featured vehicle: 2007 GMC Yukon Denali ...
Jan 22, 2016 | Cars & Trucks
Printer feeds more than one sheet at a time
clean the rollers and replace the sep pad or sep roller which is the bottom roller, first one is pickup top one transfer bottom sep. or replace all
May 20, 2014 | Konica Minolta PagePro 1350W Laser Printer
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My HP Deskjet 1220C printer picks up several pieces of paper when only printing 1 page. Picking up multiple pages when ony printing 1 page.
THE SPERATION PAD IS DIRTY OR WORN.TRY CLEANING THE SEP PAD WITH NAIL POLISH REMOVER.THE SEP PAD IS LOCATED UNDER THE ROLLER THAT PICKS UP THE PAPER
Feb 28, 2010 | HP DeskJet 1220c InkJet Printer
Feedroller on mdf on xerox 5675 keeps jamming. The copier has done over 200,000 copies so I'm assuming the feedroller needs changing but as yet no message has appeared to do so. Any advice?
You are right, the feedroller is worn and needs to be replaced. Is your copier in an office or your home? Is it a copier bought by you personally or by your company? The reason for that is, Xerox never sells copiers to businesses without pushing a maintenance agreement on the customer. With that, there is an 800 number in the user manual for service and sometimes the number is posted on the copier. Unless you have a tech available to order and replace parts, you will have to call Xerox.
Oct 20, 2009 | Office Equipment & Supplies
ALL ERROR LIGHTS FLASHING
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
Use the Service option from Printer Properties to start service--maintenance----or you need to service your printer from vendor.....
Oct 01, 2009 | Dell 1700n Laser Printer
My sunroof won't close
I tried to change my main headlamps both were working fine the i changede 1 it worked went to change second one and now nither work home muy 2001 volvo s80
Apr 05, 2009 | 2001 Volvo S80
Error c 0210 minolta di 450
Sir,
You mite have a problem with XFER/SEP HV Connection in the first Di450. Also the Housing's on both end of the XFER/SEP assy may need replace ment that would be the two white assy at each end of the XFER/SEP assy. There breaking down due to HV. Also have you replaced the two corna wires in each unit their very fine gold plated wires very thin. They mite have broke or have toner over them clean with alcohol be careful they are very fine wires.
Oct 11, 2007 | Minolta DI-2010F Copier
HP LaserJet 4730 MFP Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
