Question about Yamaha 2006 VK Professional
Ihave a 2006 vk professional with no spark what should I try and where to look
Thinking it is a coil somewhere
    Champion:
    New Friend:
  • 220 Answers
Follow your plug wires back to the coil and then change it.
Posted on Oct 02, 2014
98 Yamaha 700 vmax xtc snowmobile has spark getting gas new plugs new battery won't start won't pop tors unplugged won't do anything but turn over
Try spraying a little starter fluid into the air intake. If it tries to start, the carburetor needs adjustment or cleaning and rebuilding or replacing. DO NOT USE A LOT OF STARTER FLUID!
Dec 03, 2017 | Yamaha 2007 VK Professional
2007 vk professional running hot,engine light on,codes 21,84 on
I have the book but I cant find the codes.
So find out if your rad fan is coming on. If it does then pull out your thermostat and place it in a pot of water and see at what temp it opens at. The open temp should be stamped on the thermostat.
If it is stuck closed or opening to slow, replace stat.
Mar 15, 2014 | Yamaha 2006 VK Professional
Where do you add gear oil on a 2006 yamaha vk pro
There should be a dip stick on the chain case remove it and add oil there. until it is full on the shight glass.
Hope this helps.
Feb 15, 2014 | Yamaha 2006 VK Professional
How to adjust gear chain on Yamaha VK pro
Locate chain tension bolt.
Loosen locknut.
With 2 fingers tighten the lock bolt until it is tight.(not crazy tight)
Then back off the lock bolt 1/4 of a turn.
Hold bolt and tighten lock nut.
You are done now.
Dec 29, 2013 | Yamaha 2006 VK Professional
1991 srv boggs at half throttle. what are some things I can check?
Hey Dave,
Have you replaced the air filter?
Try running it without the filter to see of that makes a difference..
bad gas will not cause this.. Sometimes its cheaper to take it to a professional..
Jun 24, 2017 | Yamaha 2006 VK Professional
How to replace spark plugs in a 2006 honda accord
First park the car somewhere flat and disconnect the battery. Remove the engine cover, unbolt the ignition coils and release the harness connector from each one and then pull the coils off of the spark plugs. Once the spark plugs are exposed, you can remove them with the spark plug socket. Reverse for install. Good luck
Mar 27, 2011 | 2006 Honda Accord
I have a 2006 F150 with a 5.4. I have a engine
First remove spark plug. #8 plug is, if sitting in truck, left rear plug. Have someone crank engine while you hold spark plug, connected to plug wire, ground plug to ground. Check spark. If no spark, remove plug wire from coil, connect test light from coil to ground, see if you get spark, if no spark replace coil. Leave cylinder #8 open to air to dry any unburnt fuel in cylinder.
Sep 25, 2009 | 2006 Ford F-150
Wont start
u are losing the spark from somewhere probely need a new coil, if u have a spark try turning the mixture screw down on the carbs
May 03, 2009 | 2006 Aprilia RXV 4.5
Yamaha 2006 VK Professional Logo
429 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Gene Tuck
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
