Maytag Neptune washer door lock will not stay locked
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Possible computer board problem. contact Maytag,
Posted on Mar 31, 2014
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune washer will not
youll need to remove the 3 screws across the topo of the console, the console will flip forward and youll be able to see the machine control board. look toward the mid to lower left side of circuit board and locate the blue relay box, just above that you should see a resistor with a quite apparent burn mark all around it, if so youll need to replace that control board, as well as the wax motor in the door lock/latch asssy
Posted on Apr 05, 2008
SOURCE: Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Posted on May 18, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
  • 5 Answers
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
oldmanewtoys
  • 414 Answers
SOURCE: mah4000aww no door locked light
The lid/door safety switch needs replaced
Posted on Mar 08, 2010
Maytag Neptune washer door lock doesn't lock
I am hoping you did not fry any circuit boards so your just want to know how to replace the door lock wax motor. I will leave a step-by-step youtube address that shows and explains how to do it. How to change your Maytag Neptune door latch wax motor
Mar 31, 2014 | 12002535 Neptune Washer Door Lock Wax...
I s a Maytag Neptune washer error code "FL" something I can reset myself?
Error on the door lock or the door switch, try and use a switch cleaner, remove and reset the lock or check the harness to the switch
click this link: Door lock
Jan 20, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer, Model: MAH5500
The problem is with your door lock set.You may need to
replace it.If your lock is faulty the washer wont begin its
cycle.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag front louder door won't lock or even stay shut?
it sounds like you have broken the switch which keeps the door latched when not in use as well as locks when the washer is started. These latches often fail when someone forces the door open to add more clothes without pushing the pause button AND waiting until the "locked" light goes off. Older children and teens and yes, uninformed men, are apt to do this. You will need a repair person.
Jun 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
My neptune does not extract.  My clothes come out dripping wet.
I am having the same problem, and have found that the door lock light is not on, and that the door lock does not seem to be working. This would keep the machine from spinning.
Is your door lock light on?
Jun 14, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
