Question about Canon PowerShot A95 Digital Camera
All pictures are very dark using my Canon Powershot
This has been happening for a few months now - I've tried everything, changing the flash settings, the picture mode - to no avail. What do I do?
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jun 15, 2009
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 | Watches
    I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
    A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
    Jun 06, 2011 | Canon Cameras
    I have an M520 that used to take great pictures - now lately the picture is distorted and seems to be all grainy/green. I've tried each of the options, resolutions, brightness controls, etc. Sometimes...
    QUESTION:::::::::: I have an M520 that used to take great pictures - now lately the picture is distorted and seems to be all grainy/green. I\'ve tried each of the options, resolutions, brightness controls, etc. Sometimes (not every time) after I make a change to the brightness or resolution or white balance setting the picture goes back to normal - but not everytime. Most of the time it\'s just unusable because it\'s so distorted... almost like it\'s over exposed? I\'ve literally checked every setting available to no avail. I want to say it started happening after doing a firmware upgrade. Anyone else having that problem?
    answer: i never knew the answer in exam also i cheated fron s 10's boy, the invigilator scolded me but i drank dew ans said daar kay aagey jit hay and continued my cheating program.
    so u also cheat the solution of ur desk partener OR buy NOKIA 1100 its perfect 4u ********!!
    Nov 11, 2010 | Samsung SPH-m520 Cell Phone
    Need instructions for setting my armitron wr165 , 45/6967 watch.
    This model is not available on Armitron's website, but after working through a similar digital watch, I came up with the procedure.
    Basically, hold the MODE button for 2 seconds until the alarm flashes then press SET to get to the minutes. Press ADJ to change the numbers. Press SET again to change the hour.
    Here's the full date/time set:
    SETTING THE TIME AND CALENDAR 1. Press and hold 'MODE' for two seconds. Alarm Modeappears. Release 'MODE', then press 'MODE' again. Seconds and the TuesdayIndicator flash. Press 'EL' to zero out the Seconds. 2. Press 'SET'. Minutes flash. Press 'ADJ' to advance the Minute. 3. Press 'SET'. Hours flash. Press 'ADJ' to advance the Hour. 4. Press 'SET'. The Months flash. Press 'ADJ' to advance the Month. 5. Press 'SET'. The Date flashes. Press 'ADJ' to advance the Date. 6. Press 'SET'. The Day of the Week flashes. Press'ADJ' to advance the Day of the Week. 7. Press 'MODE' to end set sequence and return to thetime.
    Nov 07, 2010 | Microwave Ovens
    I have a Canon Digital EOS Rebel XT and the built-in flash no longer pops up when needed. This started happening after using a Canon speedlite, but then removing it. I've tried resetting everything, and...
    In addition to resetting all the camera settings you should also choose the "clear all custom functions" option that is also available from the same menu. Once that's done. Put the camera in Full Auto mode and see if the issue is resolved.
    Sai.
    Oct 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
    How do u get hourly beep to turn off on digital watch
    To set time, date, and options:
    1) With time and date showing, press and hold SET.
    2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
    3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
    4) Press NEXT. Minutes flash. Press + or to change minutes
    5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
    6) Press NEXT. Month flashes. Press + or to change month.
    7) Press NEXT. Day flashes. Press + or to change day.
    8) Press NEXT. Year flashes. Press + or to change year.
    9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
    step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
    chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
    from mode sequence).
    Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
    Complete Timex link site:
    http://www.timex.com/info/Product_Instruction_Guides_Downloads
    Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
    If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
    I hope this helps you. Thanks, Bill
    Aug 31, 2010 | Timex Watches
    I bought a Sony DSC t700 approximately 6 months
    If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
    To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
    If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
    When shooting MPEG movies
    When set to the Twilight mode
    If an external flash is connected
    If in the Burst or Multi Burst mode
    Please touch the MENU option on the screen of the Camera.
    Then, select the REC MODE under the MENU.
    Then, select NORMAL under the REC MODE.
    If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
    First, please touch the HOME on the LCD screen of the Camera.
    Then, select the SETTINGS in the HOME menu.
    Then, select the MAIN SETTINGS under the SETTINGS.
    Then, select the Initialize under the MAIN SETTINGS.
    If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
    It's required to physically examine the Camera to determine the exact issue at the service center.
    Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
    No more flash?
    I have done a lot of photography, some professionally, and am old enough to have used film cameras longer than I have used digital :>)
    My immediate thought is what ASA speed do you have the camera set to? If it is something like 3,200 ASA, rather than 200 ASA which your film may well be, everything is going to show overexposed in normal light. Perhaps 3,200 ASA is an exaggeration, and in the reviews below, the ASA specifications of the camera as regards metering are not mentioned. Guessing it will be in Mode - Settings?
    Nikon 35Ti Review - Ken Rockwell
    www.kenrockwell.com/nikon/35ti.htm
    The Nikon 35Ti was a rich guy's vacation camera. The model name means 35(mm lens) and Titanium covers. It cost about a grand ($1,000) when it came out in ... ‎Introduction · ‎Specs · ‎Performance · ‎Usage
    Discovering the Dreaded Nikon 35Ti - by Marc-Olivier Gilbert - 35mmc
    www.35mmc.com/21/09/2015/nikon-35ti-guest-review-marc-olivier-gilbert/ Sep 21, 2015 - If you asked me 6 months ago, I never thought I would want a compact camera. But that was 6 months ago, and now I have a Nikon 35ti. nikon 35ti Google Search
    Mar 15, 2017 | Nikon 35Ti Quartz Date Point and Shoot...
    How do I change time on timex watch?
    These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
    These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
    TIME AND DATE
    1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
    2. Press ADJUST to set SECONDS to zero.
    3. Press START/STOP to select MINUTES.
    4. Press ADJUST to change.
    5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
    6. Press MODE when done.
    7. To display DATE from Time display , press START/STOP.
    8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
    9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
    ALARM AND HOURLY CHIME
    1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
    2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
    4. Press ADJUST to change.. Press MODE when done.
    5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
    CHRONOGRAPH
    1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
    2. With time displayed, press MODE to select Chrono Mode.
    3. Press START/STOP to start.
    4. Press ADJUST to view lap time. Press again to sesume lap timing.
    5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
    6. Repeat for successive laps.
    Have fun! - Not a bad watch for the money! - - Silver Bullet
    Mar 16, 2007 | Timex 5B841 Wristwatch
    Canon PowerShot A95 Digital Camera Logo
    62 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
