Roper washing machine model RTW4640YQ 0 will fill
Roper washing machine model RTW4640YQ 0 will fill agitate but won't spin out drain
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Have you unplug the power source? Any codes flashing on the machine? Possible belt is worn and or pump is worn. If the machine is older than 10 years..get a new one..
Posted on Mar 31, 2014
  • 30 Answers
SOURCE: roper model ras8445kq0
If the agitator does not spin at all, then it is your motor coupling. If the agitator tries to spin but cannot, then it is your dog agitators.
Posted on Mar 14, 2008
appldoctom
  • 311 Answers
SOURCE: KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Posted on Jan 04, 2009
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
  • 56 Answers
SOURCE: ROPER 4 CYCLE 2 SPEED DOES NOT AGITATE OR SPIN
Disconnect power should be a motor coupling broken you take off the cabinet, two phillips head screws left console bottom on back and right console bottom left on back and pull toward you and rollback the console two funny looking brass colored springs insert screwdriver into spring and push back toward back of washer and it will jump out. disconnect the lid swithch and lean cabinet out and looking down inside at front bottom slide out 2 inches to remove cabinet. then two black clips that hold pump on and then two screws and same except larger clips that hold motor on remove wiring harness and lift motor out and youwill see coupling either broken there or on transmission replace with part number 285852A from 1-877-262-1479 to put back on use hammer and 3/8 or 7/16 socket and extension and hit litely untillyou push metal center onto motor shaft then repeat for transmission side put rubber coupling on transmission side and line up motor and doall in reverse to put back together. tip on cabinet clips set in place and push down with heel of hand to snap into place
mike
Posted on May 31, 2009
I have a Roper ras7133kq1, top load washer. About 3 months ago I replaced the lid switch because it wouldn't drain or spin. Now it will ONLY spin, it won't fill with water or agitate, the only way...
If it won't fill you will need to replace the "water inlet valve" on the back of the unit. The unit will only agitate if it gets the signal from the water level pressure switch.
Here is the valve to order.
Nov 22, 2012 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Roper model ras8445kq0
Mar 14, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
278 people viewed this question
Top Washing Machines Experts
