Question about Boating
Clean well kept
No spark
    Top Expert:
  • Boating Master
  • 42,778 Answers
Actually can not tell you what it might be with such little information . What has no spark ?
Posted on Apr 01, 2014
I have a Hitachi NR90GC2 nailgun and it isn't sparking. I've serviced it and charged the batteries but nothing happens except that the indicator light keeps flashing red!! Please help or advise.
There is a cascade(tripler) that will have problems or may be the isolator in the high volt cable internally to the point where the spark is its a difficult job to do it must be removed try the last aid to use cold cleaning solvent the whole assembly with cable a very little change but after cleaning and blow it dry with a compressor may be a little change
Aug 25, 2015 | Hitachi NR90GC2 Cordless Gas Clipped Head...
Which way do I tilt my efco lawnmower to clean without mixing oil and petrol it is model LR53TBX ?
You;re usually safe if you tilt it so that the cylinder (spark plug) is kept at the highest point.
Mar 08, 2015 | Garden
I have a craftsman mower model no 917.28922 that blows blue smoke after engaging blade and is using oil..maintained and kept very clean after every use...what should I check, has new spark plug.
If your maintenance did not include changing oil each season that made the engine wear out sooner. Clean on the outside does not help the inside. You can get a price on rebuilding the engine but I have a feeling that you can replace the mower for not much more. Use it till it dies if you plan to replace it.
Feb 14, 2015 | Craftsman Garden
2006 yamaha pw50 electric start, all it does is crank i replaced the spark plug and batterie it is getting spark. it had oil and fuel in the air filter do you have any idea why its not starting
IF you are getting spark then you must not be getting fuel. the carb probally needs cleaned, check to make sure that there is no **** in your gas tank, because i dont think that there is no fuel filter on them. I have a older on and no fuel filter **** in the tank kept clogging the carb every time i cleaned it. I put a filter on it to stop that
May 23, 2011 | 2006 Yamaha PW 50
Show me how to replace spark plugs
Relatively simple procedure, un screw the old plugs and insert the new ones. make sure the ports are kept cleaned and free of any debris.
Apr 27, 2011 | Champion International Champion& Small...
I have a craftsman 24 hp lawnmower that drops one cylinder and then after a while it starts firing again. happens several time per mow.could it be the ignition module. i have tried everything else i know...
sounds like u have a failing coil if u have access to a timing lite u can use that to confirm.connect to one spark plug wire and run untill a cylinder fails u will see timing lite go out if u loose spark.test both sides
Aug 12, 2010 | Garden
My 2002 Hyundai Elantra Gt (2.0L)engine runs rough during low speed acceleration, but runs fine at highway speeds. I have changed fuel filter and spark plugs, but after engine is warm it still misfires...
The Hyundai online shop manual and my newly arrived Hyundai shop manual kept pointing to the coil as a possible problem. While preparing to check coil continuity I discovered the pigtail connected to the bottom of one of the coils was loose and the contacts were burned. This is the coil that supplies spark to plugs 1 & 4, the same ones that kept showing up each time the check engine light illuminated. After cleaning the contacts and making sure the pigtail was securely attached to the base of the coil I have had no further problems.
Jun 11, 2009 | Hyundai Motor 2002 Elantra
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
