Question about Panasonic DMW-FL360 EXTERNAL FLASH f/L1/FZ30/50
Charge time too long.
How do I reduce the charge time from 7-8 seconds down to 2-3 seconds?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
Put in fresh batteries. Flashes are notorious battery drainers. As the batteries run down the charge time lengthens.
If the unit does not charge in about two seconds with fresh batteries then it may need service.
Posted on Mar 31, 2014
Lost charger
if you are right and it has been discharged for this long it will take a long time for it to start to charge.it could also not charge ever again. batteries have to have a minimum off 1.5volts to be able to recharge. if it drop lower than this it cannot charge. now sometimes you can jump start the battery with a slightly higher voltage but only to the battery not in the unit. goes as follows. 1.5v battery jump 3 seconds on 3volt. 3v battery jump 6volt 3 sec, 9volt jump 12volt 2 seconds, 12volt 14-16volt 2 seconds 2 times. 14volt and 16volt is max 24volt 1 second at 3 intervals. all these are set at a 3amp no higher amp.
Mar 05, 2014 | Emerson 7" Atsc Lcd Tv Etv-070 Black...
Tip
Charging you laptop battery by Ultra fast charger
Some producers argue charger incredibly reduced charging times of 30 minutes or less. Cells with well-balanced and operating at moderate temperature, nickel-cadmium Dell Inspiron 1525 Batteries designed for fast charging can indeed be applied in a very short time. This is done simply dumped in a high charge current during the first 70% of the charge cycle.
In the second phase of the charge cycle, the charge current should be lowered. The absorption efficiency of the Asus M6000N battery charge is reduced gradually shifts to a higher charge state. If the charge current is still too high in the later part of the charging cycle, the excess energy is transformed into heat and high pressure cell. Eventually, the ventilation will occur, releasing oxygen and hydrogen. Not only reduce the gases escaping the electrolyte is highly flammable! A white powdery substance accumulating in the mouth area indicates the previous outburst.
Ultra-fast charging can only be applied to Dell PC764 battery that are designed for rapid recharge. Applying a high current charge for normal cells will cause the conductive path to heat up. The contacts on the portable packages also suffer if the current arrangements for contact management piston spring is undervalued. These contacts can wear out prematurely. Often, a fine and almost invisible crater appears on the tip of the contact, causing a high resistive path and forms an insulator. The heat generated by a bad contact often melts the plastic. touch voltages exceeding improve the flow of current.
old Dell Inspiron 1501 Battery with high internal resistance and the corresponding cells do not lend themselves to ultra-fast charging, even if they were designed for it. Low conductivity cell is transformed into heat, which further deteriorates the cells. Weak cells which have less capacity are fully charged before the others and begin to heat up quickly. Some HP 530 battery create enough heat to soften and distort the plastic case. Temperature sensing is a prerequisite for rapid and ultra-fast charging.
Several manufacturers offer chargers wrist. Interspersing short bursts of discharge between each pulse of charge can further increase the charge. This method promotes the recombination of oxygen and hydrogen gas, resulting in accumulation of reduced pressure and temperature of the lower cell. Pulse chargers are also known to reduce the crystalline formation (memory) for Nickel-based. Most of the Cadex Inspiron 1525 Battery charger for dv8000 Battery based on nickel implement this function.
Some advanced chargers adjust the charge current according to Dell Inspiron 9300 Battery capacity to accept charge. A DELL E1505 Battery takes a charge initially very high current. Towards the end of a tax, the current is tapered down. batteries have aged since their respect and are automatically charged at rates appropriate to their condition.
on Apr 21, 2010 | Computers & Internet
Tip
Tips on changing orifice size on AC or heatpump
Tips on changing orifice size on air conditioners and heat pumps.
A smaller orifice will create these changes
1 - Takes more refrigerant charge to get the same superheat
2 - Increases capacity
3 - Decreases Energy Efficiency Ratio
4 - Increases Head pressure
5 - Increases sub cooling
6 - Reduces suction pressure
7 - Increases Watts and Amps
A Larger orifice will create these changes
1 - Takes less refrigerant charge to get the same superheat
2 - Decreases Capacity
3 - Increases Energy Efficiency Ratio
4 - Decreases head pressure
5 - Decrease Sub cooling
6 - Increases suction pressure
7 - Reduces Watts and Amps
on Jan 26, 2010 | Heating & Cooling
I have a Pandigital Novel 7" Tablet that will not turn on, what do I do?
Dear Please Try it;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 29, 2012 | PANDIGITAL Novel 7
Charge the battery
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 13, 2012 | Apple iPod touch Second Gen (8 GB,...
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
My nokia 5300 very short trem use cell. than very few second low battery?
Ifthe battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jan 30, 2011 | Nokia 5300 Grey Cellular Phone
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Panasonic DMW-FL360 EXTERNAL FLASH f/L1/FZ30/50 Logo
52 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
