Maytag Neptune door lock won't lock it turns off and machine will not start
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Contact maytag.. Check for error codes.
Posted on Mar 31, 2014
Amigaman
  • 248 Answers
SOURCE: maytag washer door boot
   Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Posted on Oct 21, 2007
SOURCE: Maytag Neptune door lock
you need a new door lock switch
Posted on Aug 07, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
  • 5 Answers
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
oldmanewtoys
  • 414 Answers
SOURCE: mah4000aww no door locked light
The lid/door safety switch needs replaced
Posted on Mar 08, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag-MFW9700SQ1 start button
The start button will not operate if the door lock switch is not energised.
Jan 26, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
It says the door is not locked
There are two switches in the door latch and they both need to engage. Check it with voltmeter. Most likely bad door latch assy.
Maytag Neptune repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer Maytag Neptune
Check the door lock,if the latch does not fall in place correctly the door will send the message to the electronic board that the door is open.
May 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
