Question about Panasonic Lands Phones
I have the Panasonic modular switching system KX T 30810BE at home . I seem to be unable to connect BT broadband via the phone socket. Any suggestion?
The system does not allow me to add broadband , is that correct? At present I have a separate independent phone line for broadband ; an expensive solution . Any thoughts?
  • 90 Answers
The system will not pass broadband through it
you will need to connect router direct the the bt socket
Posted on Jun 01, 2014
CORDLESSGURU
  • 106 Answers
SOURCE: I am unable to change the time on my phone to reflect the day time savings
You will need to enter programming mode. Here are the directions.
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by setting the switch on the end of a display phone to PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following.
  1. Set switch on end of phone to "PROGRAM" (or push PROGRAM key if you have one)
  2. Dial "0"
  3. Enter year (last 2 digits)
  4. Enter month (01-12)
  5. Enter day (01-31)
  6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.)
  7. Enter Hour (01-12)
  8. Enter Minute (00-59)
  9. Press 0 for AM 1 for PM
  10. Press "AUTO DIAL/STORE" key
  11. Return phone switch to "SET" (or push PROGRAM key if you have one)
Posted on Mar 23, 2008
SOURCE: 2 Line Cordless Phone In India
You have to buy a BT to US/RJ11 coupler and then post it to india for the UK cordless phone to work
Posted on May 03, 2009
Phonesmith
  • 113 Answers
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Posted on Mar 23, 2010
SOURCE: home telephone not working but I can still use my broadband on line computer
phone line is dead but broadband works perfect
Posted on Jul 19, 2010
SOURCE: I have a Panasonic KX-TCD220E
I had the same problem with KX-TCD220E and BT line. Cured by changing the DSL filter.
Posted on Nov 13, 2010
Panasonic voice mail setup for model no. KX-TGA500W phone
Hello Lynda,
Trying to get the answer to turn off your BASE FEATURE...
KX-TGA500W appears to be a WIRELESS "remote"
handset that operates from your wired BASE...
A typical base will be KX-TG + (4 digits).
In ORDER to PULL an owners manual...
I am required to know the MODEL NUMBER of
your base station...
The ONE Panasonic PHONE that is connected with
a modular jack... (to the wall.. off to the central office
("CO")) and out to your friendly telephone network... via
telephone cables...
I need the BASE model number:
From thence I will be able to access your owners manual.
In the MEAN TIME:
I'd suggest that you PHONE HOME and let your phone
ring no less than 12 times... before you can say with CONVICTION... that you don't have VOICE MAIL.
It assumes a level of PHONE COMPANY
competence & skill... (I doubt).
Trust... but VERIFY.
I am here daily please comment me back... or repost your question with the BASE model number.
We can do this...
Carnac the Magnificent
Mar 20, 2017 | Panasonic Lands Phones
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
Unable to receive calls on Panasonic KX T624
There is a reset code for each handset which I believe is 790,
Jul 14, 2012 | Panasonic KX-TA1232/KX-TA624 phone
I bought a home with the Panasonic KX-t7731 phone system installed. We have a new phone number. I am unable to set up voicemail (although voicemail answers) and I am unable to retrieve my messages. Help!
What's answering the calls, is it the Panasonic system or the central office? When you figure that out, and it's locally, then post back with the model number of your phone sytsem cabinet and whether you dial 107 or 115 ot get into voice mail, or the message is left in the central office.
Carl
Aug 31, 2010 | Panasonic KX-T7731 Corded Phone
Change Extension No's
You have to go to your phone switch, I believe that all Panasonics are modular connectors. Look for a label that will correspond to your extension number. Find your other extension and then unplug and plug.
Cheers.
May 13, 2009 | Panasonic KX-T7730 Corded Phone
Incoming call rings one time and disconnects
Unplug all phones but one in jack 11 at the cabinet and have someone call in. If it doesn't work, you probably have a bad cabinet. If not, I'm guessing one of your extensions is faulty.
Carl
Apr 06, 2009 | Panasonic KX-TA308 Phone
BT phone and broadband from sky...ok i cant make or receive phone calls.bt say that they checked the line and it shows no faults..ive tried different phones on line but no joy, interactive on sky box also...
Not a total solution, but a reason , perhaps.
I have both BroadBand and Telephone from BT.
In the past they always billed you with one bill. also if your phone was cut off due to lack off payment so the BB went off also.
they have now split their billing system - and services- into two separate identities, meaning that the phone could be cut off for calls yet your Broadband will still work and vice versa.
So, i would say the problem lies with BT , even though you have ordered your BB from Sky they still have to ask BT to setup your service at the exchange. It seems that they have not checked your service for both BB and phone.
I recently had my phone cut off (BT's 'direct debit 'accident'!) but my BB worked throughout the fortnight it took them to resolve where my paid bill money was!..
So. Call your main service provider (that would be Sky if you get no bills from BT) and tell them your phone service has most certainly NOT been activated.
I recently spent 17 hours over 3 days speaking to 23 customer assistants, before reaching a manager who resolved a similar issue for me at BT.
Under their new setup BB personel cannot see your phone account and phone personel cannot see your BB account - and we get charged over 1/3rd more for this mayhem . their reason explained to me as "having everything on one bill was confusing some customers so you now have two accounts and two bills for everything" !!
your socket is fine as you have enough connection for BB which takes more bandwidth than a voice line.
Basically you have some corporate customer service red tape to hack through.
Good luck
Nov 08, 2008 | Lands Phones
BROADBAND INTERNET CONNECTION PROBLEM (WIRELESS)
Every phone socket must have a working microfilter pluged as shown on the image below.
I think you need to change your microfilters as they might have blown.
microfilter2.gif&usg=afqjcnewmdhgecg08egxbhumf4zmq8g-lq
Hope this helps,
Regards,
Abdul Qayyum
Nov 05, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Lands Phones Logo
57 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
