Brother MFC-240c had replace cyan cartridge notation
I replaced it twice with new cartridges. It asks if I replaced cartridge; I answered "yes", and then I get a "no cartridge" message.
  • 35 Answers
There is a little circuit board on the cartridge itself. You might see a bunch of gold dots or a circuit board with gold pads. More than likely inside the printer the pins that touch the cartridge circuit board are dirty or something has fallen on top like paper. This is only the case with an OEM cartridge, if you bought an aftermarket cartridge or had it refilled then the chip might not be programmed and would also say "no cartridge".
Posted on Mar 31, 2014
Mix-it-up
  • 832 Answers
SOURCE: new ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Posted on Jan 28, 2008
  • 15 Answers
SOURCE: Brother MFC-420CN Multifunction Printer Problem
power off, remove all carts, power on, reinsert carts, say yes to questions
fails then replace cyan or ink well is covered in ink
Posted on Jan 15, 2008
  • 21 Answers
SOURCE: Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Posted on Nov 05, 2008
komguy
  • 2306 Answers
SOURCE: Over-ride out of ink message Brother MFC-240C
Yes, you can cut a small piece of electrical tape and place it over the window on the inside edge of the cartridge. it has to wrap around the window tightly.
Posted on Jul 09, 2009
SOURCE: Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Posted on Oct 21, 2009
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
When I replace the cyan cartridge with a new one I keep getting the message"No Cartridge"
hi!!! in that kind of problem maybe the sensor of the cartridge was damage thats why the sensor cannot detect when you install the cartridge. Try another cartridge or maybe try the to re-install old one if the printer detect the old cartridge that means the new cartridge was defective. Thanks
May 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
New ink cartridge istallation: Brother MFC-240
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
MFC-240C colr problem
No. Just buy original carts and install them. Run the manual cleaning procedure twice. Wait overnight and repeat the manual cleaning again. Should work. (..and give the compatible ones a dump)
Jan 16, 2008 | Brother Multi-Function Center MFC-240C...
Ink Cartridges
yes you have to replace cartridge
Jan 07, 2008 | Brother Multi-Function Center MFC-240C...
Ink cartridges....
Which cart arent recognized? The yellow one or the cyan(blue) one or both?
Anyway:
Unplug machine from power. Wait three minutes. In this time take all carts out and close cover. reconnect machine to power. Machine demands carts. Open cover. Reinsert carts. Make sure that the support clip of the cart.holder is secured above the cart cover.
If you still have probs with one cart. the led contact on the circuit board is defectiv. You need a new cart holder then, which can be ordered as a spare part from a service partner near your home (see brother homepage).
Nov 13, 2007 | Brother MFC-3240C All-In-One InkJet...
13 people viewed this question
k24674
