Simple comfort thermostat
Maximum Heat Setting Too Low... The developer who I bought my place from set it up to be rented, not owner-occupied, so that the previous owner could keep some control over the maximum heat. (No AC in unit). The heat cannot be set above 70F. My other heating zones will often be set at 60F (this works OK) by my choice, so that I would like the heat setting for this zone sometimes to be 73F or above. Added and Summary of Details - SimpleComfort 2010; Heat and no AC in unit; I have already replaced the batteries, so that there are now good quality fresh new ones in stat of course. I have looked for manual or for other posts asking same question online; I will appreciate any ideas.
  • N Opt
    N Opt Apr 02, 2014
    Thermostat heat sets ok from low temps to 70F. Heating and fuel company which supplied the lines for heating fuel says that developer set thermostat limit at 70F for the high, and that there is a way to 'lock' the thermostat-controlled heat. They say that unlabeled buttons inside the stat can limit the high setting in this way, but that the fuel company employees know neither which buttons control the lock / 'unlock' procedure nor how to set those buttons. If anyone knows how to set those buttons, or where to get documentation, that would be excellent. The developer group has disbanded so that they cannot advise.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Make sure stat is in heat mode if it only heats in cool mode then wrong wires were hooked up to furnace also try pressing the hold button and see if that gets you anywhere
Posted on Apr 02, 2014
Testimonial: "Thanks for the idea about the 'Hold Button' There is not a manual anywhere for the thermostat that I have been able to find. Does anyone have an idea where that button is on the SC2010? The system does work fine up to 70F, the problem is that the highest setting available is 70 and nothing happens when the upArrow to increase above 70F is pushed. Thanks very much for the response, Jesse!"
  • N Opt
    N Opt Apr 03, 2014
    Can anyone give me a pointer to a "Hold Button" of the kind that Jesse P mentioned, or can anyone supply a link to more details, such as a manual, for the SimpleComfort 2010 thermostat?
SOURCE: Honeywell electronic thermostat malfunction for oil heat zone
Try changing the batteries.
Posted on Mar 04, 2008
  • 252 Answers
SOURCE: What is the best place to put in a manual
on an inside wall - large(est) room - near center of house - out of direct sunlight - not in or near kitchen, bath, appliance, light, or anything else that makes heat - approx 60" from floor - not close to a supply air (above a return air is GOOD)
Posted on Oct 18, 2009
  • 10865 Answers
SOURCE: valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Posted on Dec 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I've noticed two problems with my heating system
Two problems, one is a bad thermostat on zone 2. The second is the boiler. The inducer fan energizes causing a pressure switch to engage. This pressure switch energizes the ignitor. If the ignitor does not get hot enough, it will cycle again all over. The cheapest route to take is to check all hoses going from fan housing to pressure switch looking for bad connections or leaks, the second thing to do is to replace your ignitor (time for it anyway).
Posted on Jan 06, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: I have a gas boiler with 5 zone valves. The heat
The zone valve when there is a call for heat opens and the lever should give you no resistance. I am curious to know if other zones are heating ok. You could have a bad circulator or a frozen zone.
Posted on Jan 16, 2010
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
Where do I set thermostat when temp is 10 degrees outside?
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
Nov 23, 2010 | Goodman GMS90703BXA Heater
Where to I place the sensor on a wall mount heater? Also, how do I get the heat to go into the other rooms? It seems to me to be hot in the immediate area where it is placed. Thank you.
Thermostats and sensors should be installed in spaces with airflow. This means it should not be on a wall where it may be blocked by an open door or similar objects. It shouldn't be where the sun can shine directly on it (and make the sensor believe it is warmer than it actually is), not should it be on outside walls (and make the sensor believe it is colder than it actually is).
If it is a thermostat, a comfortable height is about 5 feet. This makes it easy for adults to read and set, without worrying about young children changing the settings after your leave. If a simple sensor, this 5 foot height applies still - but lower is just as good. Remember, since heat rises, the air on your face while standing may be a couple degrees warmer than when sitting. A sensor left on the floor will cause the room to feel much warmer than the desired temperature when standing and to a slightly lesser extent while seated. This also translates to higher heating costs.
As mentioned above, heat will naturally move up. Getting it to move side to side requires additional equipment. Fans do the job inexpensively and very nicely. Place them in higher locations (where the heat is) and set the speed to a low setting, aimed into the cool space. This gently moves the warm air into the cool space - without causing a breeze that may actually feel cool on your skin.
I hope this was helpful - good luck!
Nov 10, 2010 | Heating & Cooling
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
Do rinnai heaters run efficiently if turned up and down often?
Maintaining the lowest acceptable setting and leaving it at that temperature is the most economical way to run the unit. If the space is going to be unoccupied for an extended time (several hours), lower temperatures are okay. This minimizes the need to burst the heat to warm the space quicker. As I understand your unit, it minimizes electrical & gas consumption by basing the need on the temperature difference of actual space temperature and setpoint. The larger the gap, the more power and gas is consumed.
In summary, when the space is occupied, maintain a consistent temperature setting. When the space is unoccupied, maintain a lower setpoint.
Hope this helps. Good Luck. :-)
Feb 15, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Setting Amana Heat Pump Thermostat.
The 2H/1C is one stage cooling two heating. Is it s touch screen or not. I mean no buttons. If not go to mode setting. Push mode till you get to heat not emerency heat abd then set temp. Keep in touch. Rus
Nov 19, 2009 | Amana PTH123B25AJ Heat Pump Air...
Switching thermostats
The two wires are the control circuit from the heater your running. They go to the thermostat and close when it get below the thermo. setting and start the heater.
Jun 28, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
