Question about Sanyo DP46849 46 in. HDTV
Rc1050 remote cotrol for sanyo
Where is the favourites button on remote?
  • jackie oshea
    jackie oshea Mar 31, 2014
    I can't open the pdf file as I'm running Ubuntu unfortunately. I have managed to set favourites, just don't know how to access them using the remote??
I have sanyo t.v. no remote, need instructions on how to use buttons on front of t.v.
Richard, If I were you , I would go purchase a cheap remote, universal remotes can even be found at dollar stores sometimes,Walmart,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Operate Sanyo TV Menu Without Remote eHow
Sanyo TV Remote eBay
Remote Controls
Jun 06, 2016 | Sanyo Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Codes for chunghop E-H918
0168 0171 0178 0182 0186 0203 0213 0218 0219 0231 0233 0238 0309 0379 0456 0475 0611 0613 0622. Check these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Jun 09, 2014 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
My 3x PI remote cotrol lost the programe and will not open my eletric gate,i need to reprograme them how do i go about
On the gate motor or electronics there is an internal or external receiver with a button on it that can be pressed. Press this button and then press the button on the remote. This should do it. If it does not work you may need a new battery or remote. Thanks BB
Sep 19, 2010 | Garden
No remote cotrol available
Yes.
remotes.com has one.
It's the only place I can find one for TA2050.
Feb 20, 2009 | GoVideo TA2050 20 in. EDTV-Ready LCD...
SANYO REMOTE COTROL
1.check remote its working properly or not.
2.check temperature control switch.
3.put the temperature put below 16 n on the unit
4.if not working change the remote
Mar 27, 2008 | Heating & Cooling
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Dec 09, 2007 | Sanyo DS31590 31" TV
Sanyo DP46849 46 in. HDTV Logo
18 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
