Question about Cub Cadet Garden
The club cadet will start but when you put in gear it will die
    Problem Solver:
  • 19 Answers
Ideal set to low / Poor quality spark maybe plugs or coil problem
Posted on Apr 04, 2014
Honda fg100 tiller starts runs for a good amount of time then starts dying sits a bit and runs fine
gears are locking up because of lack of grease if is not to late pull
the tines off the shaft and there should be a bolt on the side to put grease in if that does not work you will need to replace worm drive and gear
Jun 13, 2014 | Cub Cadet Street Sign- tractor lawn riding...
I have a 54 inch cut Club Cadet Riding lawnmower. It is 4 years old. When it is running it is a good machine. but I am having problems starting it after not using it for a while. I put gasoline...
roght when you leave it for the winter drain the tank ,also on the bottom of the carb is a drain as well so empty it all when stored ,Now what to do now without stripping the carb is to to use the fill pipe to the carb make sure you drain it first and then spray brake and clutch cleaner down the filler pipe so the carb gets filled with this leave overnight and then open the drain plug on the carb and repaet and then try a day or so later ,cant guarantee it will work but it normally works on old VW camper van (carb) and my motorbike .
Nov 07, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Dies when shifted into gear
May be having problems with engine vacuum leaking. Pull the large hose going to the vacuum operated brake booster and block off the hose end with a cork or other plug. Start the engine and see if it runs more smoothly. Set the emergency brake and put in gear--does it idle smoothly? If so, then you likely have a bad vacuum leak within the booster unit. Restore the vacuum hose to the cylinder and arrange to replace the cylinder.
Aug 01, 2009 | 1993 GMC Sonoma Club
Why do i not have any spark on my dodge truck?
timing belt or chain broke or slipped , coil has gone bad ,crank position sensor, ignition module i would start with the timing chain
Jun 22, 2009 | 1997 Dodge Ram 1500 Club Cab
Garden Logo
53 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
