50PV400 LG has sound no backlight
The TV has sound but no picture
4 Suggested Answers
barbu51
  • 566 Answers
SOURCE: Lg 32LC2DU-UE lcd tv sound and backlight but no video
Hi barry
To answer your question;
Strange coincidence but i repaired the same tv model that you have yesterday and for the exact same problem so here`s the fix;
In your power supply on the 5volts line there is two 3300mfds/10volts capacitors gone bad and that caused the voltage to drop to 4 volts(not enough to shutdown the set but enough to kill the video)
You`ll recognize these capacitors by a rounded top and some fluid that leaked out, you can replace them with 3300mfds/16volts since the 10 volts variety is harder to find.
And while your at it you should inspect and replace the other capacitors in that area that have the same look
Good luck and keep me posted
Posted on Jan 21, 2010
  • 11800 Answers
SOURCE: Just bought an LG Plasma
The tv is faulty and the fact that it failed immediately after you have started it for the first time is a clear indication of a manufacturing defect.
Take the tv back to the seller and ask for a replacement one or your money back.
Posted on Jun 01, 2011
SD Tech
  • 14553 Answers
SOURCE: I HAVE LCD/TV LG M227WA the picture and sounds are there but no backlight.what's the solution?
A backlight will either not light because of no voltage or no control (not being switched on by the set).
Posted on Apr 04, 2012
I have a 2-1/2 year old LG 60LB7100 TV. When I turn the TV on I get the Lg logo and sound but then I loose picture.
The back light driver can be incorporated in either the power supply board or the main board (model specific). Contact these guys and they will make sure you get the correct part. TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 28, 2017 | LG Televison & Video
How to fix an lg 47LE5400 tv power lights come on but no picture
If it's a led tv and if you have sound and, also, if you can see the picture with a flashlight very near on the screen in the dark, that means your backlight or your inverter circuit that control the backlight are defect. Good luck,
Serge.
May 06, 2016 | LG Televison & Video
LG 42lv4400 LED TV powering on with sound and backlight OK but no picture
The Tcon Board or the LCD panel is faulty
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 05, 2016 | LG 42LV4400 42 in. HDTV
LG smart 47ln5700 the screen will go black i still have sound but no picture i could make out the picture in some angles need help on what parts i should replace(picture with flashlight on it)
Hi Angela,
The backlight system of your TV has failed. Mostly it is the inverter part inside the TV which makes necessary power for the backlights fails. The power/inverter board needs to be repaired or replaced.
May 26, 2015 | LG Televison & Video
LG plasma 50pv400 after power surge when turned on only shows black screen with occasional blinking yellow horizontal stripe, is it worth trying to fix or should I just buy a new tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
aults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
May 05, 2015 | LG Televison & Video
I have an LG 60 inch plasma model 60PV450 that has no picture but does have sound
It is probably the backlight inverter board. These are common problems on all LCD and Plasma units that use fluorescent backlighting.
Jan 20, 2015 | LG 60 60PV450 Plasma TV
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
Just bought an LG Plasma Screen TV. 50' 50PV400 I turned it on, and the picture was there. After a couple minutes the picture is no longer available and the screen turns black while the sound...
Jun 01, 2011 | LG Televison & Video
Lg plasma have sound but no picture tv made a popping noise then lost picture can change stations but no dispaly on tv
your lcd backlight has a problem probbably the ballast try to replace the the backlight ang the ballast this can solve the problem...
May 17, 2010 | LG 42PC3DC 42 in. Plasma HDTV
LG 42" Plasma - Sound but no picture
HI,
I'll think that either your backlight or de backlight -driver, -supply is not OK.
Kind regards,
Gerard
Oct 21, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
