How to remove motor on my wt540
How do i remove the motor on my wt540 hotpoint washing machine
  • 3 Answers
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Posted on Dec 01, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint wt540 can't get filter out
It is possible you have got something stuck in filter, and this is what is stopping it coming out, you are turning it the right way, you will just have to stick with it, and keep trying to ease it out.
Keep trying to eaes it in and out, and you should be able to remove it eventually.
Plz rate this solution.
Thanks.
Posted on Dec 14, 2008
amgm
  • 32 Answers
SOURCE: can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Posted on Feb 19, 2009
barkencoa
  • 3463 Answers
SOURCE: am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
Posted on Jun 03, 2009
barkencoa
  • 3463 Answers
SOURCE: The door catch on my Hotpoint Aquarius WT540
You need to seperate the 2 halves of the door, remove all screws securing the 2 halves together, and prize apart.
You will then see how all the parts are fitted.
Posted on Dec 29, 2009
Wash light coming on door locks then nothing happens ?
Most likely motor brushes. Try it without any thing inside, give it a little spin with your hand.
Outside chance motor plug has wobbled loose.
Jul 26, 2015 | Hotpoint Aquarius WT540 Front
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
Hotpoint Wt540 1400 wont spin
check the machine washes ok if it does not turn the drum on wash check the motor brushes if drum action is ok on wash check the drain pump for blockages
Mar 06, 2014 | Hotpoint Aquarius WD63 Front Load...
Machine wont spin
check motor brushes or blocked pressure chamber.
Feb 09, 2014 | Hotpoint Aquarius WT540 Front
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
The door catch on my Hotpoint Aquarius WT540 washing machine is broken. I have ordered replacement parts but need instructions on how to fit them. Can you help please?
Dec 29, 2009 | Hotpoint Washing Machines
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
