Question about Canon Office Equipment & Supplies
Reflashing error code 000602-0413
How to clear error code cfa35 on a Konica Minolta c352
Copier Operating system firmware crashed need tech to reflash
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 10, 2014 | Konica Minolta Office Equipment & Supplies
Minolta c550 error code C-D403
Controller error could be a bad main board, have tech come out try to reflash the firmware (copier operating system) not driver
Dec 04, 2013 | Konica Minolta Magicolor Office Equipment...
sir, mam
LTO1 error code 4
The LTO 1 error code 4 means "A firmware or drive problem has occurred."
You might try reflashing your firmware, which you'll find here.
I hope that helps.
Mar 14, 2011 | IBM (08L9762) LTO 1 Tape Drive
JVM Error 545 - Blackberry Pearl 8110
to correct this issue try this method
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Aug 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
Nokia 5610, security code problem
hi,the code was typed too many times. take out battery for 30-40 minutes. and then try 12345. if no joy then reflash the phone (do a back up before reflashing as you'll loose all your data).
rate me if helped,thanx.
Apr 14, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
P62 error code
The IBM 6400 printer uses internal programming software that is specific to the printer based on installed interfaces and graphics options. This software resides in flash memory and when the printer is first powered on the software is executed. During this process it initializes the various processors on the controller board, initializes the optional interface cards, and then loads the necessary operating settings into dram. If the programming software becomes corrupt it will fail during startup, giving you the DC Program not valid error or a number of other error messages. The solution to this is a reflash of the printer. Unfortunately, the flash software is proprietary to IBM and they will not distribute it to anybody. The only way to get the printer reflashed is by calling IBM and having one of their engineers reflash the printer.
Jan 28, 2009 | IBM 6400 Matrix Printer
PHONE CODE SIG ERROR
take the phone and have the phone reflash and have it fix
Jun 21, 2008 | Motorola Mobility RAZR V3
19 people viewed this question
old marine
old marine
