Open door error
Very old thread but I had this problem, the little light beam sensor had fallen off.
Its secured onto the back of the thin plastic top plate. With a torx t10 bit you can lift this plate up and clip the sensor back into position. Theres 2 screws on the front and 6 along the back, some are difficult to get to but I just took a few out and bent the plate up a bit. I blobbed a little bit of glue on while I was there to discourage it from coming off again
I would lift the top up...and on the back left corner is a slot that the tab from the lid goes into to say the top is closed, I would stick a piece of paper of cardboard in the grove, or slot and see if that works..I think it is a light beam type switch, and not a mechanical switch that telsl the printer the lid is down..so you basically blocking light when cardboard is in that slot...
Kenny
