Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Coffee not draining properly
The coffee is not draining form the pot, it comes out the sides and goes on the counter. We only get a 1/2 pot coffee, the filter is always full of coffee.It seems like the hole where the coffee is coming out of the filter is not opening. An I missing a part. If I take the pot out while it is brewing the coffee does not stop. Thank you
SOURCE: espresso won't brew
same prob
Posted on Apr 23, 2008
The Machine
  • 788 Answers
SOURCE: I have a Krup Orchestro
When you ran the cleaning cycle did you use the Krups cleaning tabs?
Posted on May 21, 2008
SOURCE: Krups Coffee pot stopped brewing after programming
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
Posted on Jun 13, 2009
  • 4090 Answers
SOURCE: my Krups coffee maker is leaking some coffee onto the counter
no normal fix it requires worshop inetervention to replace the seal
Posted on Jul 31, 2009
  • 343 Answers
SOURCE: I have Krups KT 406
Did you try it this way?
Before descaling, remove the filter holder (f).
• You may use either the Krups descaling solution diluted in 8 ounces of water or
8 ounces of white vinegar.
• Pour the solution or vinegar into the water reservoir and start the coffee machine
(without coffee).
• Allow half the liquid to run into the carafe, then switch off and let stand for 1 hour.
• Restart the coffee machine to complete the cycle.
• Rinse the coffee machine by running it through 2 full cycles with water only
I would make vinegar stronger and leave it in for a few hours or more.
I have attached a copy of the owners manual for you to download. Thanks for using FixYa; if you could please click accept solution
http://www.krupsusa.com/NR/rdonlyres/28C9969C-D788-4136-B298-EA43960B582C/28300/KM4065dahlstromUS.pdf
Posted on May 22, 2011
How do you brew a pot of coffee? Someone gave us a machine for our wedding and it just sits on the kitchen counter doing nothing.
I'm assuming you've got a coffee filter pot as this is the most common kind (especially as wedding gifts).
1. Boil the water.
2. Put the filter (should come with the pot) into the filter holder.
3. Add 2 level tbsp. of ground coffee per 6 oz of water.
4. Pour some of the hot water over the coffee grounds, giving them a few seconds to swell.
5. Now add the rest of the hot water and allow the coffee to slowly drip through the filter.
6. Remove the filter with the coffee grounds in just before the final drops of water go through.
7. Now sit down and enjoy!
Feb 25, 2013 | Home
Prepare the pot the night before and by morning all the water in the reservoir is on the floor or the counter!
I have had our Bur Grinder Cuisinart for a little under a yr. with no issues until recently when it started flooding my counter top. I could tell it had something to do with the lid or filter button that touched the lid b/c coffee would begin to "pool" and then flood over the sides onto my counter. I contacted the number listed below on 10.25.12 and was told our model's lid had a defect and they would send me a new one to resolve the issue.
Cuisinart Warranty 1-800-726-0190
Sep 04, 2011 | Cuisinart DGB900BCU Grind and Brew 12Cup...
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
While the coffee is brewing without using the grinder feature, coffee overflows onto the counter. About 1/2 of the coffee goes into the pot while the rest spills over. I have cleaned residue from the lid...
overflow problem possible causes: 1) water is over the "10" marker, 2) no filter in basket 3) too much (or too fine) of coffee in the basket -- does not drain. Also make sure the "spring" on the bottom of the basket is not stuck (the one that lets you remove coffee carafe without dripping coffee.
Jan 17, 2011 | Cuisinart Thermal DGB-600 Grinder
Brand new, first run, leaking?
You must have the carafe lid ON. The reason is the lid has a dome on top that pushes up to let the brewed coffee come down. With the pot off look in there with a flashlight....you'll see that the 1 inch dome pushes up on the spring loaded stem.
You MUST have the lid in place or the brewed coffee won't drain into the pot.
Aug 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cooks coffee pot stopped working
I bought the coffee/espresso maker. The espresso side still works, but the coffee side does nothing. I only had used it for about a week, but that was long enough for me to throw the box. I was going to contact the company but I see that will do no good, so my suggestion is to buy a new one (same exact model) then put the broken one in the box and return it. You will have a new coffee pot, and you won't be out anymore money.
Apr 16, 2008 | Cook's Essentials CEFB2B
We bought a black&decker Spacemaker coffee maker last month and it has not worked properly but maybe a week. It seems to not want to flow correctly into the pot. We set it to come on and wake up to...
If the hole in the bottom of the basket isn't plugged, it sounds like the anti-drip feature isn't functioning properly. This is the series of levers that allow you to remove the pot while the coffee is perking without spraying liquid everywhere.
There is a vertical lever mounted at the back of the hollow where the pot goes, and the top end of that lever lines up with the spring-loaded lever that closes the bottom of the coffee basket. When the basket is in place without the pot, the bottom of the basket remains closed. When the pot is inserted it presses against the back lever and the series of contacts opens the valve covering the hole in the bottom of the basket, allowing the coffee to flow into the pot. If the sequence of contacts doesn't work the basket will overflow, and you get coffee and grounds everywhere.
Ensure all these parts align and are working properly. If there's a problem that can't be resolved, or parts are broken or missing, removing the spring-loaded lever from the basket will allow the coffee to flow into the pot. You will no longer be able to remove the pot while it is perking, but you'll have your morning coffee.
Apr 16, 2008 | Black & Decker SpaceMaker ODC150 Coffee...
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
27 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
