Question about Ovens
Does not start
IK-F901 convection oven does not start after timer and temperature are set. there is a button on the back of the oven lid that needs to be pressed manually for the oven to start. if not pressed, the oven stops
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Posted on Dec 28, 2008
  • 12 Answers
SOURCE: How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Posted on May 21, 2009
SOURCE: I need instructions for chef condor convection
i have a chef condor wall oven and the door wont shut properly as the latches have gone loose or broken
Posted on Sep 24, 2010
Set timer on convection oven. It goes for 1 minute and stops. Press again it goes 1 minute. Will not stay cooking for more than a minute at a time. Help.
Switch the timer to manual if it has a button with a hand on it press this one What make is the oven.
Apr 27, 2015 | Ovens
Oven won't start
Try pushing the "convection oven" or "bake" button first, then enter the temperature you want. Then "Start".
Sep 24, 2012 | Thermador SC272T Electric Double Oven
We have recently bought a Casera 28L Microwave/Convection Oven. the Instruction Manual refers to Oreheating but gives no instructions on the procedure to turn it on. Can you help us please? Ken &...
Hi Guys,
What model have you got? I have one that I have owned for well over a year now with absolutely no problems. In fact I would have to say for the $119 I paid for it, it has been the bargain of the century so far.
My model is CAS048 and to preheat it is very simple. You set the press the convection oven button to set the temp you want (i.e 180 deg) and push start. The oven will operate until it has warmed up at which time it will beep 3 times. Open the door and put your food in and set the time you wish it to cook and you are away!
P.S, mine will shut off automatically after a few minutes of reaching it's set temperature if I don't open the door and set the timer on it, so it pays to have your food ready or close to ready when you set it to preheat as it warms up quite fast.
Apr 07, 2011 | Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    I need to clean my double ovens, but do not have the owner's manual. I know that I simple press the Clean button, but how long do I set the timer for?
    You only need to reset the time if you want a cleaning cycle other than 4 hours. The default start is press Self-Clean then Start. Otherwise, press Start, type in a time between 3 and 5 hours (Min/Max cycle length) and then press Start. Do this with the number pad, do not press the Timer button. If you wish to clean both ovens, the second one will start when the first one finishes.
    The Locked door light will go off when the oven has cooled below the Lock temperature. If you interupt the cleaning cycle by pressing Clear/Off, the door will remain locked until the oven cools.
    I hope this helps.
    Sep 25, 2010 | GE Profile JTP56 Electric Double Oven
    How to set the timer
    1. Set the oven to the required
    temperature.
    2. Press the g button.
    3. Set the total cooking time with the +
    button (see the example in the
    illustration right, showing 1 hour and
    30 minutes).
    4. Press the h button.
    5. Set the cooking finish time with the +
    button (the example in the illustration
    shows 12.30 hrs.).
    After setting the display shows the
    time of day and indicates »AUTO«.
    The oven cooling fan will start
    immediatley.
    At the pre-set time, the oven will be
    automatically switched ON.
    The settings can be corrected at any
    time.
    When the pre-set cooking finish time
    is reached, a signal sounds and the
    oven is automatically switched OFF.
    To turn the signal off, briefly press the
    h button.
    6. Turn the oven selector switch to the
    0 position.
    7. The »AUTO« symbol blinks.
    Important: It must be switched OFF
    by pressing the E button.
    Also here is the manual.
    https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
    Good Luck
    Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
    Ovens Logo
    21 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
