Question about Golds Gym XRS 30 System
Machine is very stiff
As we use this machine the feel is very stiff and a grinding type sound is loud. I assumed that perhaps one of the cords are to tight or something, just not sure.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
2004 Ford Escape loud grinding noise, power steering stiff and belt covered w oil like substance?
Sounds like the power steering pump has failed.
You could take the serpentine belt off and check the pump pulley.
Jan 30, 2013 | 2004 Ford Escape
Why does my washing machine sound like a machine gun only on the end of spin cycle?
I'm not completely sure what you mean by sounding like a machine gun. If it is banging loudly and shaking all over the place, then the tub is out of balance. Depending what kind of washer you have, it may be a simple fix. If the sound is more like a grinding/crunching type of sound, your motor coupling may be bad - again this depends on what type of washer you have. If you can tell me the brand of your washer, I can be more helpful. If necessary, I can also guide you through the fix.
Apr 11, 2012 | Washing Machines
When i turn power button on ,it sounds like grinding metal ,very loud vibrating noise.
sounds like the bearings. make sure machine is off open door put your hand at the front of the drum at the top then see if you can lift it up and down if there is alot of movement it will most likely be the bearings,or try turning the drum by hand to see if you can feel any vibration or hear any grinding noise.
Jul 26, 2011 | Washing Machines
Washer makes a loud skreeching sound when it stops
Can you let me know what the Model number is of your machine? Is it a FAV6800A or FAV9800A. So many folks post non a FAV6800A or FAV9800A machine types in this forum.
If it one of those types and you open the lid and spin the Wash Basket CCW do you here any metal against metal grinding/screeching sound?
Please don’t offer a vote for me unless I can help you DIY the issue or point you to a repair solution. Thank you…..Rich
Apr 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine started to make a loud grinding noise and does not rotate to wash nor to spin. after moving the machine i found some plastic shavings under it.
Sounds like the bearings for the drum have or are on the way out. The belt has probably broke or come off.
Depending on the age, cost of new and personal feelings it can be repaired but normally it isn't cost effective, unless the machine cost £500+ ($800+)
Jun 14, 2009 | Washing Machines
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Golds Gym XRS 30 System Logo
70 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
