Question about Radio Shack Radio Communications
How do i program a radio shack realistic pro 2021 scanner where do i find frequencies
  • 3 Answers
Go to bettybearcat .com and you can get frequencys for your area
Posted on Jan 18, 2012
    President:
  • 2,761 Answers
The factory manual contains programming instructions and a lot of other information about your scanner. You can download and print the document, at no cost, here:
Http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/PRO-2021/PRO2021_Service_Manual.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Listening in since the 60's
Posted on Sep 25, 2010
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
Will Realistic Pro 2021 receive digital frequencies?
If it does not say digital on the scanner the answer is no. If it does, most likely it is a trunking system and will require programming using software and a computer.
Nov 07, 2014 | Radio Communications
How to program freqencies on pro 2020 20 channel realistic
Wow, that's a real oldie -- circa 1981. To program it:
1. Power the scanner ON.
2. Press MANUAL .
3. Select the channel that you wish to program. You can do this by repeatedly pressing the MANUAL key, or enter the desired channel (01 - 20) followed by the MANUAL key.
4. Press PROGRAM.
5. Enter the desired frequeny, including the decimal point (e.g., 156.55).
6. Presto ENTER.
7. To program more frequencies, press PROGRAM and then repeat steps 2 through 6.
Follow this link for more operating instructions:
http://support.radioshack.com/support_electronics/doc45/45530.htm
Bill B.
Oct 23, 2010 | Radio Shack Pro-2052 Scanner
Radio scanner no volume realistic pro- 2021 model #20-113 has loud squelch but voices only whisper what is the problem and how can i fix it. Thank You Lyman
frequency may not be accurate. get the correct frequency your tuning in to. could be off a few digits. then readjust your squelch.
Feb 16, 2010 | Radio Shack Radio Communications
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
I have a Realistic Pro 2021 and it doesn't pick up no channels, and idk how to program it please help.
your scanner will have to have some crystals put in it that are specifically for the signals you wish to scan. go to any radio shack store or scanner store with your scanner and they will gladly assist you.
Sep 07, 2009 | Office Equipment & Supplies
I need to program my realistic police scanner.
for your frequency, go to the local radio shack and ask them to look up the frequency. If you have nothing to fear from your local jurisdiction, go directly to them and ask for the frequency. Programming is the easy part and obtaining the frequency not difficult.
Jun 16, 2009 | Radio Shack Radio Communications
Radio Communications Logo
928 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
